ecm
Old Jan 31, 2019 | 08:02 PM
dremtofford's Avatar
dremtofford
ecm
mine was missing on my 91 eddie baur so i need to get the right no. would one out of a wrecking yard be any good?
Old Feb 19, 2019 | 10:49 AM
dremtofford
anybody out in internet land?
Old Mar 31, 2019 | 11:55 PM
dremtofford
are the ecm the same for a 91 as for a 94 if they are both automatic, and 4x4, and 4.0 pushrod?
Old Apr 1, 2019 | 01:08 PM
shorod's Avatar
shorod
It's been several years since I thought about changing an ECM in an older Ford. It seems like there was a "calibration code" that was important when ordering replacement ECMs back before they were software updateable. It also seems like I recall a substantial change to the on-board diagnostics in Fords between 1991 and 1994. Ford didn't make it all the way to OBD-II compliant by 1994, but I think there was a rather significant improvement in the system that may prevent a 1994 ECM from dropping in to a 1991.
Also, I recall changing out multiple GM ECMs in the 80's and 90's, but I don't recall ever having to replace a Ford ECM. Would you care to share what symptoms you are experiencing or diagnosing you've done that condemned the ECM? Maybe the symptoms will ring a bell with someone more so than knowing what you can swap out. The lack of responses could support my observation that ECMs in that vintage of Ford did not fail very frequently.
-Rod
Old Apr 1, 2019 | 09:13 PM
dremtofford
my symptoms are that mine is missing, someone took mine out to use on theirs and i think it was my ex son-in-law
Old Apr 2, 2019 | 06:53 AM
shorod's Avatar
shorod
Yikes, that sucks! I guess I didn't comprehend the "missing" in your original post.
-Rod
Old Apr 15, 2019 | 11:08 PM
dremtofford
found my original. my friend put it in his 95 because the ecm was new and he thought it would work in his 95, i guess the software is different because it didn't work so he put his original one back in and a new fuel pump and it fires right up. but doesn't run good. when we changed his fuel filter black stuff came out. so next project is new injectors.
donovan
Feb 25, 2014 07:45 PM
exiled
May 1, 2012 09:32 AM
DBGrif91
Jul 16, 2011 07:15 AM
mastermind929
Electrical Systems/Wiring
Nov 5, 2010 07:42 AM
explorerphobia
Oct 3, 2003 12:30 PM
