1-2 code
Old Jan 28, 2019 | 04:23 PM
hjartland's Avatar
hjartland
codes
116
636
114
All higher/lower temps than expected. Oil, antifreeze, etc ...
Being towed to my house. Will wait out this cold snap. Then put in a new coil & battery cables.
Old Jan 29, 2019 | 09:05 AM
ZombieF150's Avatar
ZombieF150
116 normal if you haven't ran the engine and it is cold out from what I have read UNDER 50 degrees and OVER 250 will cause that if the IAC is not bad. Probably from the cold temps you have had
636 Transmission oil Temp probably caused by the cold temps you have experienced
114 Intake Air Temp. again possibly because of the temps you have had.
I bet you get the truck started warmed up and then shut down then those codes go away, but first the truck has to be started..
Old Jan 29, 2019 | 01:25 PM
hjartland's Avatar
hjartland
cold
Agreed, next I'll replace the coil. But that's a couple exteremely cold days away.
Old Feb 1, 2019 | 03:59 PM
hjartland's Avatar
hjartland
17°F :)
We're at 17°F ABOVE zero!
I plugged in a new coil. Vroom! Still have to replace the battery cables. Had to grab it and I jerked it hard. (Huhuh .. ) Anyone know where I can find the wiring diagram?
Old Feb 1, 2019 | 05:54 PM
ZombieF150's Avatar
ZombieF150
glad i started for you. as far as the cables I am not your guy on that. Not familiar with the cables on that truck.
Old Feb 1, 2019 | 06:20 PM
hjartland's Avatar
hjartland
zombie
Thank you, Zombie150. It really hrlps to have someome to troubleshoot with.
Will do the cables when it warms up. More updates then.
Old Feb 1, 2019 | 08:34 PM
ZombieF150's Avatar
ZombieF150
I would think replacing the battery cables would be straight forward. You could always use masking tape and write the location of each end on it as you unhook it, apply it to old cable then match it up when you put the new one back on.
Old Jun 12, 2019 | 10:30 PM
hjartland's Avatar
hjartland
ignore the 1-2
Ignore the 1-2 code. The insturment panel's shroud / labels was off at the time. I was looking at the wrong flashing light. Oops.
As the weather has warmed. All systems are happy. Battery cables are on the to-do list. Will update after that change. Hope that'll be the last of this issue.
Thank you all again.
oldmajor
44
Oct 17, 2025 10:31 AM
Joelong258
Jan 25, 2011 12:44 AM
TheTinian
1997 - 2003 F150
May 2, 2010 11:59 AM
RyanMackD55
Dec 13, 2007 07:53 AM
slntnddly
Electrical Systems/Wiring
Jan 15, 2004 09:23 PM
