Power/Starting Issue
Old Nov 13, 2007 | 04:50 PM
RyanMackD55's Avatar
RyanMackD55
Exclamation Power/Starting Issue
Hey fellas,
I have a 2000 F250 with 120,000miles. This morning (about 25 degrees) I went to start my truck and the volts meter was reading around 11 and the truck would not turn over. Later that night I had the same problem except it eventually cranked after some slow cranks. I have replaced both batteries and the altenator in the past six months. Any ideas as to what is causing this? It only has the issue when the truck is very cold and has been sitting for more than 6 hours.
Thanks in advance
Old Nov 13, 2007 | 05:50 PM
ryaneverk2's Avatar
ryaneverk2
Make sure that the connections on the battery terminals and starter are all good, clean, and tight. If it's not cranking or cranking weakly like you're describing, that would sound like a weak battery, or a poor connection.
Next time before you go to start it, and you're expecting it to crank weakly, test the voltage at a battery with an actual multimeter, and see what you get. Should be 12.5+ volts. Once it's started, it should be about 14+ volts to indicate the alt is doing it's job.
Old Nov 14, 2007 | 03:44 PM
clintbonnie's Avatar
clintbonnie
I would get a battery hydrometer tester..(napa has one for $20) and check each cell of the battery.. Even newer batteries can be defective. Then like Ryan says, check your battery voltage when the engine running.. should 14+ volts.. if not, your altenator might be go bad. Also, you might try putting a battery charger on the batteries, one at a time for a full charge..
Old Nov 14, 2007 | 05:10 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
id say it might be your starter. if it turns slow and gets faster . grab a flashlight, and check both bolts on the starter housing, one of mine was cracked causein intermitent slow cranking or no cranking.
i got one of THOSE beasts on Ebay and never had a problem since.
and service from this guy was great.
Old Dec 13, 2007 | 07:53 AM
mwk1000`'s Avatar
mwk1000`
I have an F-250 2002 7.3L and there was a junction box on the drivers side that the positive cable ran to/from that was completly corroded and caused the same results.
Something else to check if it is there on your model
