Battery, Starter, Charging ???
Old Jan 11, 2004 | 07:30 PM
slntnddly's Avatar
slntnddly
Question any suggestions would be nice.....out of ideas
Just recently fixed a burned out fusible link to restore power to my truck. when everything was back in order, i tried to start the truck. it started turning over with no luck starting, so i tried again and it tried to start. the next time i turned the switch, it started turning over and then started slowing down like the battery was getting drained. i checked the water level and it was fine, and the battery had full voltage. i let the truck sit for a few minutes and then went back to try again. same thing....slowed down after a few turns. could this have anything to do with old oil not lubricating the valves well enough? any suggestions are welcomed. ive been fighting with the truck for 3 mos now and im ready to get it on the road
Old Jan 11, 2004 | 08:24 PM
Greg 79 f150's Avatar
Greg 79 f150
Standing voltage on a good battery fully charged, should be between 13 to 14 volts. Not knowing the age of your battery ( dont expect over 5 years from any of them) you could have a dead cell, not letting the battery hold the cranking amps to keep you cranking. You can have decent standing voltage , but that doesnt guarantee cranking amps. With a known good battery try it again, if she spins good , then you have other problems, am not much of a mechanic, so maybe someone else here will help you out, good luck
Old Jan 11, 2004 | 11:48 PM
Racerdave's Avatar
Racerdave
Check your VR (Voltage Regulator) They are cheap and east to replace. And after that I would buy a DieHard with a 2 yr warrnty. Good Luck, oh also a VM(volt Meter) is a good investment.
Old Jan 12, 2004 | 08:18 PM
slntnddly's Avatar
slntnddly
the battery is brand new....only been in the truck a couple months
EDIT: also need to know what the "field" wire is for on the alternator. someone before me rigged a new wire that looks too small on it and just stuck it into the VR connector
Old Jan 12, 2004 | 09:21 PM
Mike W's Avatar
Mike W
The field connection is the output of the regulator. Voltage on it is what makes the alternator start charging. It only draws a couple of amps so you don't need large wire for it.
Old Jan 12, 2004 | 10:01 PM
Franklin2's Avatar
Franklin2
Is it fully charged?
Old Jan 13, 2004 | 06:14 PM
slntnddly's Avatar
slntnddly
the battery is showing about 12.1-12.2 volts
Old Jan 14, 2004 | 03:05 AM
Mike W's Avatar
Mike W
The battery is low. You should see 12.6 with nothing on.
Old Jan 15, 2004 | 09:23 PM
peppy's Avatar
peppy
Even a brand new battery can have a bad cell. It happens. Usually in the rain.
