Engine Removal
Old Jan 26, 2019 | 01:26 PM
RageOfAntioch's Avatar
RageOfAntioch
Engine Removal
Looking for engine removal tips and tricks to save time and energy
1984 Ford F-150 302
Does the hood need to be removed or will it clear?
Engine lift plated bolt to intake manifold Pros/Cons?
Size bolts to bolt Engine to stand?
Leave exhaust manifolds on or remove?
Anything tips or if someone has a good walk through would be greatly appreciated
Or a step by step best order to do things in to save time
Old Jan 26, 2019 | 01:56 PM
Franklin2's Avatar
Franklin2
Take the hood off. Take something sharp and scratch the paint right around the rectangle hinge pieces before you loosen the bolts. This will help you align the hood back where it was.
Take the radiator out
Engine lift plate would be good. It will let you tilt the front of the engine up.
You will have to take everything loose, lift the engine and the trans up (the trans is usually stuck to the engine some) till the motor mounts clear the frame brackets. Then take a jack and a piece of wood and put under the transmission to support it up high like that, then let down on the engine a little bit, the engine will usually break loose from the trans. Then lift it again till it clears the motor brackets, and pull it on out.
RageOfAntioch
Jun 27, 2017 07:26 AM
Montync
Apr 10, 2016 10:28 AM
ssg1957
Jan 11, 2015 12:52 PM
maestro1024
21
Mar 18, 2013 08:37 PM
Wawnosh
Jun 28, 2011 01:38 PM
