EBPV Operation Questions
Old Jan 25, 2019 | 11:29 AM
Firefighter 1406's Avatar
Firefighter 1406
I have a question. I had a break in my daily 7.3 driving for 1 year so my “ear” for all things 7.3 is a bit off. It has been cold here been 20 during the day, dropping to 0 or below at night. When is the EBPV supposed to work? Are there operational parameters? It seems the EBPV in my truck is workring too good. But maybe I am wrong. It has been snowing so speeds have been 60 or below. The exhaust has been hissing all the time. Only stops when I am off the throttle. As soon as I am back on the throttle it’s right back to hissing. I am wondering if I need to adjust it? Is it possible to adjust? Any thoughts or knowledge bombs would be appreciated.
Old Jan 25, 2019 | 12:51 PM
Colorado350's Avatar
Colorado350
Could you have a boost leak since it’s only when on the throttle?
Old Jan 25, 2019 | 01:26 PM
DieselDenny's Avatar
DieselDenny
To be honest with you Seth, I disabled mine and just let it warm up before rolling. It became a big PITA with the noise of a jet and the throttle response. I'm colder than you up here and I see no Ill effects.
Denny
Old Jan 25, 2019 | 02:08 PM
fordboy2's Avatar
fordboy2
I deleted mine over a year ago and never looked back, even as cold as it is here right now. (As cold as -8 and suppose to be colder yet) truck warms up fine and the oil leaks are gone.
Old Jan 25, 2019 | 02:40 PM
Walleye Hunter's Avatar
Walleye Hunter
I believe that it's all temp based using your IAT vs EOT but I don't know what the triggering numbers are. Mine went out when the van turbo went in because it had to. So...until your oil temp reaches the necessary temp it will close. Under heavy fuel it should open up. And watch your EGT's while it's closed, they will climb.
Old Jan 25, 2019 | 02:46 PM
Hussler's Avatar
Hussler
What year is the truck? The EBPV system should kick in on a cold start with EOT ~32 degrees or lower depending on some other sensors such as IAT. At your low temperatures I'm sure it's actuating though. Depending on the PCM code and year of truck the PCM looks at EOT to determine if operation is necessary. When the truck first starts in cold weather the PCM will cycle the EBPV and expects back pressure from the EBP sensor. If it see's back pressure it assumes a working assembly, if not it disables the function. This operation only occurs if the EOT is below ~135 degrees, depending on the PCM code and year of truck. Anything above ~135 degrees the PCM could care less and assumes engine is warmed enough and disables the function on a restart.
Here's the kicker though. On my 97 the function won't go away until EOT is ~175 degrees or above and if still driving, such as waiting for a light change and it drops below ~175 degrees the function continues If monitoring EOT and I see "say" 150 degrees, kill the engine and restart the function is disabled and never comes on during the rest of the driving cycle. On cold mornings it's hard to get that engine temperature up to that level.
I'm pretty much an expert on the 97 model EBPV system operation but not so much on my 99. You indicated the hissing sound which is probably the valve closing. Demand for more power by the foot should open the valve but this takes a few seconds due to the mechanical nature of the device, hard to do in snow and ice conditions. If you can monitor the EBP sensor data this becomes clear as you will see higher back pressures while driving, as much as 43 PSI. Usually when cruising it's in the upper 20's to mid 30's.
Old Jan 25, 2019 | 03:00 PM
Hussler's Avatar
Hussler
Mark, I've never seen EGT's climb as boost is zero with higher EBPV pressure, cruising, if anything they go down. Somehow the PCM compensates fueling, don't have a clue how though. Of course this is stock injectors and PCM programming so anything else I'm sure it would affect what you indicated.
Old Jan 25, 2019 | 04:00 PM
Walleye Hunter
Right near my house here there's a hill that I have to climb at a slow pace and when that valve is closed the EGT's hit 1000 quickly (when I had the valve). But then mine is live tuned and the PCM adjusting for that might be taken out of the mix.
Old Jan 25, 2019 | 04:01 PM
Dan V's Avatar
Dan V
I would check to see that the EBPV tube is clear.
Old Jan 25, 2019 | 05:43 PM
Firefighter 1406
My truck is an E99 with a 2001 engine. I just put the engine in July. I will check the tube again but it should good to go. By what you guys are saying it sounds like normal operation. I just don’t remember it functioning as much as it is now. It will stop on more moderate throttle but like mentioned it’s a little difficult on snowy roads.
Old Jan 26, 2019 | 09:40 AM
bigb56's Avatar
bigb56
In answer to your adjustment question, there is an adjustment procedure that gets the EBPV preload within spec but it is done on the bench with a spring scale. When I replaced my turbo a few years ago I did the adjustment and although I seldom visit cold country, when I do the EBPV operation is great. It raises my idle soon after starting but doesn't seem to affect normal driving except for slightly reduced power, but I don't ever push it hard when it is cold anyway.
Old Jan 26, 2019 | 09:59 AM
Pocket's Avatar
Pocket
This is the answer.
If the backpressure valve continues to remain closed when accelerating, the sensor tube is clogged with soot.
Old Jan 26, 2019 | 11:28 AM
calbertomendoza's Avatar
calbertomendoza
Another possibility that I rarely see mentioned -- the actual EBPV can get stuck shut. It happened to me and I had no boost and no power. I had to disconnect the actuator rod and spin it with a vise-grip, and pull with considerable force to pull the rod out, and get the flapper open. I believe I used a piece of mechanic wire to tie the rod where it couldn't shut.
Eventually, I'll get a new non-EBPV pedestal but for right now it works. It must not happen very frequently because I never see it mentioned, but it is a possibility.
Old Jan 26, 2019 | 02:01 PM
Hussler's Avatar
Hussler
Mark, you are correct, I misspoke, sorry Guess what I was trying to say is the EGT's never went above a critical mark anytime when accelerating with stock components and valve working.
You are correct. It's a bit concerning but if you can monitor EBP sensor when driving it becomes clear what the PCM is trying to do vs throttle response. In winter months it's an interesting parameter to watch along with EOT. Only once did my observations fail over the years as the engine temp (EOT) was up and no operation on the valve. Pulled into a fast food drive in to get breakfast and pulling out the valve closed again but outside temps were about 9 degrees and in freezing fog. Guess AIT has some input on this decision.
MTP55
Apr 5, 2018 05:33 PM
aflannery97
Jan 6, 2018 11:59 AM
Pigman54
Jan 7, 2014 08:41 AM
Giuseppe1425
Feb 18, 2010 08:19 PM
Bluebronco85
Nov 1, 2009 12:00 AM
