Sponsored by: Real Truck
Odd throttle response when cold.... Maybe.
Old Apr 5, 2018 | 02:55 PM
MTP55's Avatar
MTP55
Truck is an 00 7.3. For both cases. My boss and I have both recently experienced this with our trucks. I'm not sure if I'll explain it right but I'll give it a go. It only happens when the truck is cold. I do warm my truck up before I move it but sometimes will give it a little idle time and then once it goes to high idle I'll slowly move it out my driveway and down the road. We live on dirt roads. It seems that when I do this I'll be just pulling out of the driveway, so I'm at about 1000-1200 rpm I think, and lightly on the throttle then it's like the computer or something tells everything to move faster. You could probably explain it as kind of a jump. The truck doesn't move any faster but it goes from quiet to loud. Like all the injectors just started firing harder as they do with acceleration. Is that normal or do I have an issue? The truck behaves well any other time. I thought maybe it had to do with the cold or possibly where I was in the throttle when moving it out the driveway slowly.
Old Apr 5, 2018 | 05:26 PM
mcnance865's Avatar
mcnance865
Sounds like the EBPV opening up now that you are under load and higher rpm, thus higher temp. Do a search about the EBPV if you're not familiar. In a nutshell, it partially closes the exhaust to make the truck warm up quicker.
Old Apr 5, 2018 | 05:27 PM
mcnance865's Avatar
mcnance865
If it also makes a sort of "whoooshing" sound and then clears up. That is the EBPV opening all the way.
Old Apr 5, 2018 | 05:29 PM
MTP55's Avatar
MTP55
Not sure it makes a whooshing Sound. I know it's fast. Almost scares you because it's suddenly there and then about as soon as it comes it's gone.
Old Apr 5, 2018 | 05:31 PM
mcnance865's Avatar
mcnance865
I mean is it making the constant "whooshing" sound while cold and until it suddenly stops and then the "jump" as you describe it happens. Does this sound accurate?
Old Apr 5, 2018 | 05:33 PM
MTP55's Avatar
MTP55
That could be. I'll see if I can replicate it tomorrow and see what I hear.
mike71800b
Nov 18, 2017 10:38 AM
badblueoval4life
16
Jan 4, 2012 09:48 PM
armstrongfordtrucks
Dec 29, 2010 02:26 PM
Giuseppe1425
Feb 18, 2010 08:19 PM
Mustangfreak
Oct 16, 2004 02:19 AM
