Coolant temperature sensor?
Old Jan 22, 2019 | 11:27 PM
homertwo's Avatar
homertwo
I finally figured out how to use Forscan. (Just the basics so far)
Anyway, I did a check on the sensors and found the Coolant temp sensor was reading -4
I bought a sensor from Autozone and installed it. Now my temp gauge does not move.
The coolant sensor shows -168 and then drops to -140 after a few minutes. Why the negative numbers?
I have tried to find out if there are 2 coolant temp sensors on my engine.
I have a 2000 F550 with the 7.3 by the way. I read the reviews on the Autozone site and someone said that the sensor I bought was for the ecm not the gauge, but when I took the connector off of the sensor and grounded the red wire, my temp gauge pegged.
Are there 2 sensors? The one I changed is down by the thermostat housing. If there is another one, where is it?
Thanks for any help.
Old Jan 23, 2019 | 02:34 AM
Wes444's Avatar
Wes444
Originally Posted by homertwo
bought a sensor from AutoZone...
Guessing you too have a ZF6 since i hear these autos don't have coolant sensors, just a formula based off engine oil temp? One thing you'll see mentioned time and time again is Motorcraft/International brand sensors only on these motors. All other brands will fail out of the box or within a few months. Buy once cry once
Old Jan 23, 2019 | 06:41 AM
AllaboutMPG's Avatar
AllaboutMPG
Pretty sure you need a motorcraft sw5130.
See this thread https://www.ford-trucks.com/forums/1...ct-sensor.html
Old Jan 23, 2019 | 06:46 AM
Colorado350's Avatar
Colorado350
The algorithm must be off on Forscan that’s why your numbers are off, I get the same thing using UltraGauge. If you want a true Coolant temperature you’re going to need a separate gauge and tap in water pump or into Coolant filter if you have one. As Wesley mentioned only OEM sensors you’ll save yourself a lot of time and headaches.
Old Jan 23, 2019 | 08:13 AM
Walleye Hunter's Avatar
Walleye Hunter
Coolant temps are not readable with an automatic transmission. OEM sensors only so put your original sensor back in and carry on.
Old Jan 23, 2019 | 08:45 AM
AllaboutMPG
IIRC when I replaced mine the parts house sensors looked identical in size, shape, and electrical connector but with an ohm meter read 10 times the resistance.
savage250
Feb 1, 2012 10:43 AM
duback66
Jun 29, 2011 04:42 PM
stemo76
33
Oct 3, 2009 07:44 PM
Fordbronco69
Dec 14, 2008 07:10 PM
danwink
Jan 23, 2005 07:20 AM
