Coolant temperature sensor
Old Jun 29, 2011 | 03:09 PM
duback66's Avatar
duback66
I have a 92 f150 with a 4.9. The temp. gauge always reads too cold and I changed the thermostat without any differance. I suspect that the coolant temperture sender is bad on the side of the block and am planning on changing it. However I check the resistance on the coolant temperature sensor (the one by the thermostat) and am getting no resistance at all between the two pins.
Does anyone know if I am doing this test right? There are two pins on the sensor and am not sure if I am suppose to check betweent the two or from one to ground. Thanks
Old Jun 29, 2011 | 03:55 PM
rla2005's Avatar
rla2005
The sensor on the front of the engine is the Engine Coolant Temperature sensor (ECT) for the PCM. It should measure between ~500 to 115k Ohms between the two pins.
For reference: Ford Fuel Injection » Engine Coolant Temperature Sensor (ECT)
Old Jun 29, 2011 | 04:42 PM
subford's Avatar
subford
The sensor you are looking for, for the gauge:
corksil
52
Aug 9, 2021 03:28 PM
tonyford
1983 - 2012 Ranger & B-Series
31
Nov 9, 2019 02:28 PM
pineconeford
16
Jul 18, 2014 07:28 PM
smelskya
15
Mar 23, 2014 04:37 PM
RebusCom
Sep 21, 2013 04:28 PM
