Sway Bar end links after Ready Lift 2.5 Level
Old Jan 21, 2019 | 07:25 PM
Angry Tomato's Avatar
Angry Tomato
Anyone had any issues with knocking noise over small bumps at low speeds after having this level installed? I have the caster corrected with bushings, running 37's with, blistein shocks, track bar relo bracket installed/ spring swap not spacers.
Noise is coming from the front driver's side footwell and it sounds almost like its end links on the sway bar. Truck has 1500 miles on it. I've checked every bolt on its all tight. Is it likely to be the end links with so little miles on it?
Old Jan 21, 2019 | 08:18 PM
Snowman 8's Avatar
Snowman 8
Just a guess, but is the bolt on the end of the track bar tight enough? I think that its the one that needs to be torqued to 450lbft. Mine was loose after my level was installed and I had a clunk in the front end.
I’ve also had shocks cause clunks while hitting bumps. It took some convincing to get a nearly brand new shock covered by warranty but once they were replaced the clunks were gone... good luck
Old Jan 21, 2019 | 08:24 PM
bobv60's Avatar
bobv60
lower shock mount bolts is the first place I would look, they need to be TIGHT
Old Jan 21, 2019 | 08:31 PM
Angry Tomato
Thanks @Snowman 8 . I did remind them to torque it up to the 405ftlb and not the 250 in the instructions. Whether they did I've no idea but if thats it I'll be a bit pissed. I have new Blisteins with the kit so i hope it isn't the shocks. I'll pull the shocks off and see if it disappears.
Old Jan 21, 2019 | 08:38 PM
Snowman 8's Avatar
Snowman 8
As bobv60 said I would for sure check the lower shock bolts also. Now that I had a chance to think about it my 17 had a couple noises, one was the track bar bolt and the other was the drivers side lower shock bolt. I put my impact wrench on it and just let it hammer away for a few seconds then the noises were gone.
Old Jan 21, 2019 | 09:00 PM
Angry Tomato
Thanks @bobv60 . I'll stick my big impact on it and get them snugged up some more.
Old Jan 22, 2019 | 07:17 AM
2017-350's Avatar
2017-350
Mine had a knocking noise and it was the puck in between the spring and the top of the housing. It shifted a hair in installation and wasn't sitting correctly in the spring.
Old Jan 22, 2019 | 08:03 PM
Angry Tomato
Mines a spring/coil replacement.
Old Mar 7, 2025 | 06:57 PM
Qualls59's Avatar
Qualls59
1st Gear
Did you ever find any answers to this? I'm having the same issue with my 17.
Old Mar 8, 2025 | 05:03 PM
Tricon's Avatar
Tricon
I had this and it was the sway bar joint was loose. Replaced the end link and it went away. Took me forever to figure out.
Old Mar 9, 2025 | 08:37 AM
jimzpsd's Avatar
jimzpsd
For what its worth, ... I removed my front sway bar to allow better off road flex, plus no more noises. The street ride is fantastic too.
Old Mar 9, 2025 | 09:51 PM
JayCarver's Avatar
JayCarver
I pulled my sway bar a couple years ago just to see what it would be like and never put it back on. Prefer without it.
It’s not a big job to pull it OP, maybe you could try and see if your noise goes away? And you might just like it gone anyways.
tracyclifton
Feb 9, 2015 09:41 PM
bookem15
2004 - 2008 F150
Dec 23, 2010 03:20 PM
abes250
Oct 22, 2008 09:04 AM
atillett
Mar 14, 2008 07:56 AM
riverbedjed
Sep 1, 2003 01:10 PM
