Modular V10 (6.8l)
Open port?
Old Jan 20, 2019 | 05:05 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Open port?
Hi All,
I'm about to buy a 1999 F-53 motorhome with a V-10. While I was inspecting before I test drove I noticed this port that appears to be open when it shouldn't be. It is located on top of the engine above the #5 cylinder (passenger-side rear of engine). It has a gasket that fits the engine side of the port, however, the fitting on top of it is bolted to one side of the port and doesn't cover the other.
Is this normal?
What is this port for?
Thanks!
Close
Far
Old Jan 20, 2019 | 07:23 PM
Sam I Am's Avatar
Sam I Am
a post I made last time I saw this asked
Originally Posted by Sam I Am
Because the heads can theoretically swap sides with additional machine work.
Instead of 2 different gaskets, they all make the same gasket for both sides.
If it was on the other side it would have the thermostat housing over it.
If they made 2 different gaskets there would probably be 50% of people on here wondering about the hole AND complaining that their thermostat housing leaks.
The hole doesn't go anywhere, it's just there.
It is supposed to be like that.
It isn't going to leak provided that you have torqued the intake bolts correctly.
Everyone freaks out the first time they see it, but that's just the way it is.
Old Jan 20, 2019 | 08:37 PM
CathedralCub
FTE Community Team
Cool, thanks Sam I Am!
I wasn't quite freaking out, I looked into it etc. and it looked like it went nowhere. The thing I couldn't get over is the half-utilized gasket complete with O-ring.
Thanks!
Old Jan 21, 2019 | 11:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What's funny is, most who notice this "hole to nowhere" have vans
WELCOME to FTE!
Old Jan 21, 2019 | 06:34 PM
CathedralCub
FTE Community Team
Interesting . . . I'd guess that's because vans tend to get the wheels driven off of them therefore cause more maintenance to be needed therefore have more people looking under the dog house . . . while Class A motorhomers maybe seldom look under there at all . . . ?
WELCOME to FTE!
Thanks! This is a busy board with lots of good information!
Old Jan 21, 2019 | 08:59 PM
krewat's Avatar
krewat
No, because those with vans can get the doghouse off
F-series, who the heck looks all the way back there unless they are REALLY digging around ?
Yeah, busy place. Lots of good people.
Old Jan 22, 2019 | 12:03 AM
Sam I Am's Avatar
Sam I Am
That area on a truck is under the non-removable cowl. You would have to be literally laying across the top of the engine to see it or using a mirror.
Old Jan 29, 2019 | 12:07 PM
CathedralCub
FTE Community Team
Ah yes, that makes sense. It's easier with many class A motorhomes. Usually just two latches then lift (while sitting on nice carpet with optionally-activated HVAC and the TV going). This is the first time I've thought to myself "after I get this thing I can wait until snows to do spark plugs".
Old Jan 29, 2019 | 12:10 PM
CathedralCub
FTE Community Team
I hadn't thought if it that way until you and Krewat mentioned it. I always forget how far back under the windshield these things are in the pickups.
BendLarry
Modular V10 (6.8l)
Mar 19, 2019 12:05 PM
benbuilder
Mar 4, 2018 05:24 AM
abe
15
May 31, 2017 07:38 PM
LUPO DI MARE
33
Jul 6, 2016 12:40 AM
andrewscofield
Jan 18, 2013 09:00 PM
