P1876 question
Old Jan 18, 2019 | 06:22 PM
xcrsp440's Avatar
xcrsp440
P1876 question
2004 F350 4x4 270k miles. Factory ESOF hubs that work.
Just got back from a 2000 mile trip and checked for codes and got this 1876, Transfer case 2wd solenoid short to ground. The switch on the dash is in 2wd, no bucking or indication while driving that the front wheels are engaged.
Tried manually rotating front drive shaft, won’t spin. Tried reversing and applying brakes, still can’t make it spin.
During the trip needed to use 4wd and when I turned the switch to 4hi or low, all tires hooked up.
Does anyone have a part number for this solenoid or a pic? I tried searching but have not been successful. Just that it is located on the passenger side of the case.
I can drive as is because the hubs don’t lock until vacuum is applied, but I would like to get this fixed.
Thanks
Old Jan 19, 2019 | 11:52 AM
xcrsp440's Avatar
xcrsp440
Here’s an update. Went to the ford dealer to try and figure out the part based on the code. Couldn’t find the solenoid mentioned so I am stuck. Will keep researching but if some knows please respond.
Old Jan 19, 2019 | 06:02 PM
Nummy76's Avatar
Nummy76
Idk about that code but I had the same problem of front drive shaft being locked in. So I locked in hubs and while driving down the road I engaged and disengage the 4 wheel drive and that fixed it
Old Jan 19, 2019 | 07:14 PM
xcrsp440's Avatar
xcrsp440
Upon more research and discussion with ford dealer, the code usually references the PVH solenoid. This is the solenoid that sends pulse vacuum to the front hubs. Odd that the definition of p1876 mentions transfer case?
The solenoid is located near passenger battery and I picked up replacement. Will try swapping them tomorrow.
Old Jan 19, 2019 | 09:10 PM
Motohead911's Avatar
Motohead911
It is funny that you mention the PVH solenoid throws a P1876, because I was having a P1832 and P1876 code. I just replaced my solenoid because it was leaking vacuum and both my codes have gone away.
Old Jan 19, 2019 | 09:44 PM
xcrsp440's Avatar
xcrsp440
What symptoms did you have with your codes?
Old Jan 19, 2019 | 09:52 PM
Motohead911
When I switched the truck into 4wd the light on the dash would indicate that I was in 4wd, but I wasn't. Found out the hard way in the snow. Anyways I know the transfer case switched because when I manually locked the hubs I was in 4wd and was able to drive out of where I was stuck. Also my HVAC defaulted to defrost.
When I got home I did some troubleshooting and determined that my vacuum leak was caused by the PVH solenoid. I ordered a new OEM, put it in and solved my leak. I by chance clear my P1832 and P1876 codes and they haven't come back.
Old Jan 20, 2019 | 05:03 PM
xcrsp440's Avatar
xcrsp440
Well this was unexpected. I ohmed the new solenoid and got 49 and 50 ohms which is what I expected, then tried old one and it was 119, so bingo, installed the solenoid. Old one was out of spec, went for a drive and now I have two codes. P1876 is still there but I picked up p 1832 which is for 4wd transfer case.
Why would replacing the solenoid give me a new code? It was OEM.
Thanks
Old Jan 22, 2019 | 09:22 PM
xcrsp440's Avatar
xcrsp440
Anyone else have ideas on this one?
Old Jan 22, 2019 | 10:43 PM
87crewdually's Avatar
87crewdually
Check I think fuse 27 & 111. Then check the relays near the front drivers side fender under the hood. One is the LOW & the other is the HIGH that operates the shifter motor on the t-case. And ultimately check the motor on the t-case.
Heres a schematic so you can see the wiring.
Old Jan 23, 2019 | 07:39 AM
xcrsp440's Avatar
xcrsp440
I appreciate the diagram and will check those areas next.
Chiphtr6va
Jan 12, 2019 08:36 AM
DarkyDizzle13
Dec 31, 2017 06:24 PM
X5188
Mar 30, 2015 09:35 PM
mesnipe
Jan 10, 2015 11:40 AM
Rus01
6.4L Power Stroke Diesel
Dec 10, 2013 03:03 PM
