6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
4 wheel drive not engaging
Old Dec 2, 2013 | 06:12 PM
Rus01's Avatar
Rus01
I have a 2008 F350 6.4ltr and sometimes the 4wheel drive won't engage?? Any ideas why this happens?
Old Dec 2, 2013 | 09:07 PM
aquaman's Avatar
aquaman
I haven't tried using 4WD mode in a while, but I'm pulling 2 codes:
P1876 Transfer Case 2-Wheel Drive Solenoid Circuit Failure
P1832 Transfer Case Differential Lock-Up Solenoid Circuit Failure
sigh..
Old Dec 2, 2013 | 09:24 PM
longview1's Avatar
longview1
Banned
Vacuum leak/pump?
Old Dec 4, 2013 | 11:55 AM
DesertRider's Avatar
DesertRider
when 4WD fails to work, try manually engaging the hubs. If that worked, then its a vacuum problem to the hub solenoid or the solenoid itself. I had this problem and it was the solenoid (part # tC3Z9H465A).
Old Dec 4, 2013 | 04:10 PM
aquaman's Avatar
aquaman
I'll look at it this coming weekend, but how much did that set you back? How did it fail? I started reading some docs and the first thing they suggest was the wiring or burned contacts on the solenoid circuit
Old Dec 4, 2013 | 04:52 PM
DesertRider
Aquaman, my reply probably does not apply to your problem, since your truck threw codes indicating a transfer case issue. I was replying to the original poster. My issue was fixed with extended warranty. I had the same issue with my 2003 F250, also fixed with warranty.
BTW it's easy to lock hubs manually so its a good thing to try if 4WD fails to engage. BTW I had just driven onto the sand at Pismo (with 4WD engaged, I thought) when I got stuck. Very embarrassing. I started digging out when I thought about manually locking hubs and when I did the truck, thankfully, moved on with no problem.
Old Dec 10, 2013 | 02:33 PM
Ghost00TJ's Avatar
Ghost00TJ
I tried this the other day, could'nt see the PS tire-pretty sure (only by feel) when my hubs are in AUTO and xfer is in 4x4High the front wheels are not getting power. I can feel the xfer is in a lower range. Rear fishtailing up the hill of snow and the front not pulling, same in 4x4Low.
I turned the hubs to LOCK and both axles were powered in HIGH and LOW
Old Dec 10, 2013 | 03:03 PM
aquaman's Avatar
aquaman
Just an update from my end... I went through the checklist of stuff in the repair manual.
First test was to see if the solenoid valve works by grounding the left-most and right-most connector pins while the ignition was on. Yup, the valve clicks each time and the vacuum pump in front of the driverside firewall started pumping as long as I had it grounded (valve open). Does that mean a vacuum leak?
Connections appear all good, but I must be blind or I can't find the 4x4 control box to test the connections between it and the valve...
xcrsp440
Jan 23, 2019 07:39 AM
jwharris
Nov 25, 2015 09:41 PM
monkey_nuts
2004 - 2008 F150
Jan 20, 2013 09:48 AM
ke6zmy
Sep 4, 2012 05:01 PM
John Thomas II
1983 - 2012 Ranger & B-Series
Oct 12, 2009 05:12 AM
