Lowering
Old Jan 16, 2019 | 06:21 PM
classicrat52's Avatar
classicrat52
Lowering
So I just bought a 78 f150 reg long box and I am looking at lowering it, I’m wondering how much of a drop a leaf spring flip does and how much do I need to drop the front to make it level? And what I need for the front to do so, don’t want it sitting on the ground but definitely needs to come down, never lowered a truck before any suggestions or tips would be greatly appreciated
thanks from Southern MANITOBA
Old Jan 16, 2019 | 06:53 PM
HIO Silver's Avatar
HIO Silver
You'll typically need to drop the rear end 2 to 2.5 inches to make it level with the front.
The easiest way is to flip and reposition the front leaf spring hangers. More details in the Tech Info Compilation.
Old Jan 16, 2019 | 07:07 PM
classicrat52
From the measurements I pulled I’m looking for 5” drop in the rear and 2” in the front for the stance I’m looking for. The front has coils and where do I find the tech tip? Still learning site sorry, thanks for the help tho
Old Jan 19, 2019 | 06:20 AM
User 71024's Avatar
User 71024
I've never tried to lower a 2wd, but it has a twin I-beam setup in the front, so changing the ride height is going to ruin the stance, if you go down the top of the tire is going to go in, it's gonna look like the idiots that lower their Hondas by cutting the springs, unless you alter or replace the I-beams.
Old Jan 19, 2019 | 10:03 AM
hivoltj's Avatar
hivoltj
If you mean flipping the rear on top of the leaves it will lower the rear exactly the thickness of the axle tubes. In my case about 5.5". It also stiffens up the ride and eliminates wheel hop as the axle has less leverage on the springs.
I now have the same size wheels all around and am considering going to shackles and hangers and removing the flip kit.
Old Jan 21, 2019 | 11:14 PM
classicrat52
After doing a bit more reading I think I’m going to go with shakles and reposition the original hangers
classicrat52
Jan 16, 2019 07:12 PM
chris starscream
1961 - 1963 F100 Unibody
Apr 27, 2016 12:00 PM
antunez13
Dec 10, 2007 01:23 PM
danfish
Feb 21, 2007 01:32 PM
NateDog07
Mar 15, 2006 10:23 PM
