another lowering question?
Old Dec 9, 2007 | 04:17 PM
antunez13's Avatar
antunez13
I have a 2wd 86 F150short bed standered cab, well i was wondering how hard is it to put (2")lowering springs in, and if i get a shackle kit for the back (2") could i alsopulla leaf to get more drop and if so how much and which leaf. sorryfor so may ?
im sure someone can help me, it any the shop getting painted right now so im ready to get the rest of the look down.
Old Dec 9, 2007 | 04:30 PM
flareside_thunder's Avatar
flareside_thunder
If you're going for a level look you'll need more than a 2 inch drop for the rear...as for the fronts I don't know if anyone makes 2 inch lowering coils, I haven't looked for them either.E-bay has the 2 inch drop shackles for the rear for 43 bucks....You could pull a spring but I wouldn't......might play with the way your truck handles and not give you the ride you're looking for.JMO
JR
Old Dec 9, 2007 | 05:25 PM
antunez13's Avatar
antunez13
Well i found airbagit.com has a pair of 2"lowering coils for 89.00 and i can get shackle kit for 37.00 im not looking for level i like the rake i would just like to drop the back end some more than 2" but not enough for the flip kit. I have an s10 thats lowered i know ride quality might suffer with pulling the leaf but i wasnt sure how much a f150 would drop with pulling a leaf.
Old Dec 10, 2007 | 12:29 AM
86F150302's Avatar
86F150302
I want a rear shackle kit also. Where can I get one?
Old Dec 10, 2007 | 05:30 AM
lowridaz22's Avatar
lowridaz22
I went to www.godfathercustoms.com and found some kits, check these links:
http://www.gcustoms.com/product_list/category_id/5/subcategory_id/138/Lowering_Kits
http://www.gcustoms.com/catview/category_id/5/subcategory_id/139/Lowering_Parts
Just put in your year / make / model on top and it will automatically narrow it down. I found several for the 1986 f-150.
Hope this helps!!
Old Dec 10, 2007 | 09:58 AM
86F150302's Avatar
86F150302
Hope this helps!!
Thanks alot! Ill be getting those 2" drop shackles whenever I get some more money.
Old Dec 10, 2007 | 01:23 PM
mudgepondexpress's Avatar
mudgepondexpress
Before you go all gung ho...2" drop shackes do NOT give you 2" of drop! If you are lucky you might get 1" out of it but I promise you will not get 2". The Hanger is where most of the drop comes from and if you only lower 1 side of the leaf, you only get (roughly) half the drop of the body of that of the spring (wow is that a mouth full).
I have installed the belltech drop hanger and shackle and varied between the top and bottom hole on the shackle. When I did a body measurement it was 1/2 inch difference between the 2 mount positions.
Kenny
