1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
lowering
Old Dec 20, 2015 | 12:11 AM
chris starscream's Avatar
chris starscream
lowering
Looking to lower my truck a little. Not much. Maybe 2 or 3 inches....what's are my options?
61 unibody.
Old Mar 8, 2016 | 04:27 PM
ICareyNoCash's Avatar
ICareyNoCash
I took 2 leafs out of each of the fronts and have ordered 65 and up drop shackles for the rear. found them on amazon for about $35. haven't got the shackles yet but it looks like its gonna lower the truck 2-3 inches.
Old Apr 22, 2016 | 02:25 PM
Sully1190's Avatar
Sully1190
I was told there are some systems that come with single leafs or something to that effect to achieve the same effect? I ask because I need to replace my leaf springs in the front anyways
Old Apr 22, 2016 | 05:35 PM
chris starscream
I'm not very familiar with leaf spring suspension, but would removing some of the leafs weaken the suspension? Will this give any issues?
Old Apr 25, 2016 | 07:56 PM
Fish-N-Fool's Avatar
Fish-N-Fool
The best way to lower leaf spring is to re-curve them. This can be done with a large hard block of wood about 16" high, (like a stump) and a sledge hammer. Take the spring apart and re-curve each leaf to the height you need. Turn the arch up and hit with the hammer in the middle. Work the whole length of the spring by moving it on the block till you get the curve you want. Just match all the leafs to the same curve and bolt them back together.
Old Apr 27, 2016 | 03:37 AM
Tedster9's Avatar
Tedster9
Be sure to eat yer Wheat-Chex that mornin'.
Wait, what?
Old Apr 27, 2016 | 12:00 PM
Fish-N-Fool
Wait, what?
If you use proper technique, it's really not very hard. The key is to use a hard flat block of wood about 12" to 16" around and a long handle sledge, put the spring on with the curve down and hit the spring in the middle. You don't really have to hit it what hard to recurve a spring. Just move, hit and move, hit. I did this when I used to race a 65 Mustang in a street stock class that you could not use lowering blocks. Start with the main leaf and measure the drop in height from the spring eyes to the center of the spring perch. Match all leafs to the main leaf. Say your main spring has a 5" static curve, if you recurve it to 4" it will lower the car about 1" then you put it all back together.
Blacksnake
Aug 27, 2009 09:08 PM
tonydlt
Mar 15, 2007 07:45 PM
danfish
Feb 21, 2007 01:32 PM
ZZMAXX25
16
Jul 12, 2005 04:31 PM
QuickerPickerUpper
Jul 12, 2003 09:21 AM
