Modular V10 (6.8l)
weird idle
Old Jan 14, 2019 | 08:05 PM
speedybill's Avatar
speedybill
Trailering
Angry weird idle
99 F350 dually 2wd
V-10, 200,00 miles
Idle goes up & down, sometimes it will stall,
no codes, cannot find any vacuum leaks, going to replace PCV valve,
any ideas?
Old Jan 14, 2019 | 10:54 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by speedybill
99 F350 dually 2wd V-10, 200,00 miles Idle goes up & down, sometimes it will stall,
no codes, cannot find any vacuum leaks, going to replace PCV valve, any ideas?
Also, check your IAC - Idle Air Control valve.
Old Jan 15, 2019 | 11:06 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like a stuck IAC - the computer is trying to control the idle and can't.
Old Jan 15, 2019 | 04:42 PM
V10man's Avatar
V10man
I've had 2 IAC valves go bad, one on a V10 and another on a 4.6L. neither threw a code.
Old Jan 17, 2019 | 04:21 PM
speedybill's Avatar
speedybill
Trailering
Thank The the help.
II picked up an IAC.
Can I take the throttle body off to make it easier to replace it?
Old Jan 17, 2019 | 06:13 PM
R&T Babich's Avatar
R&T Babich
Thank The the help.
You can, but there is a gasket between the throttle body and the intake that might need to be replaced.
The IAC has no input to the PCM so there would be no codes for it.
The throttle body butterfly plate completely closes at idle and the only way the engine gets any air is thru the IAC valve which is controlled by the PCM.
Old Jan 18, 2019 | 08:39 AM
speedybill's Avatar
speedybill
Trailering
Thankx
I'm going after a gasket for the throttle body.
I'll let ya know how that goes.
Old Jan 18, 2019 | 03:44 PM
rock2610d's Avatar
rock2610d
Make sure to note how old IAC is installed. I got a cheap motor once because previous owner installed the IAC upside down.
Motor will not run right if IAC is installed upside down.
Old Jan 18, 2019 | 04:12 PM
R&T Babich's Avatar
R&T Babich
....I'm going after a gasket for the throttle body. ....
While you have the throttle body off inspect the throat below the butterfly for gunk.
Clean with carb cleaner if needed.
I remember a post where idle/running issues were caused by a layer of gunk down there.
Old Jan 18, 2019 | 07:09 PM
speedybill's Avatar
speedybill
Trailering
Thankx.
Itz pretty dirty.
my72ford
Feb 25, 2019 09:27 PM
almonyspm1
Sep 21, 2013 08:27 PM
icrman
Jun 24, 2008 11:48 PM
snsgraham
Modular V10 (6.8l)
Jul 5, 2006 02:41 PM
rshep
May 8, 2005 11:29 AM
