Modular V10 (6.8l)
Scan tool recommendations
Old Dec 23, 2018 | 05:38 PM
eddienelson's Avatar
eddienelson
Old Dec 24, 2018 | 01:25 AM
Sam I Am's Avatar
Sam I Am
I would be wary of any tool that misspelled "setup" and "system" on the tool image.
Depending on what you want to do with it, I would try Forscan for free and Torque Pro for $5. Connect Forscan to a Windows computer and Torque to an Android device with a USB to OBD2 cable or a Bluetooth OBD2 dongle.
Old Dec 24, 2018 | 06:20 AM
JWA's Avatar
JWA
Timely topic as I'm in the midst of moving to something a bit more dealer-level diagnostic tool than my current Actron CP9580. That tool has been spectacular for my use but I've flirted with buying the AutoEnginuty kit and will be implementing the FORScan software in the near future.
The Actron version can be had for less than $200 new, the "outdated" model CP9690 (kit) and CP9695 (scanner only) Of course FORScan and Torque are free or cheap enough to use as a first time venture into owning some sort of diagnostic scanning tool.
I'm with Sam I Am though----buying something from an obvious "off shore" seller could be 100 times more frustrating that P0171 Lean Bank 1! If you read through the questions already asked by others you'll see this might not be the best entry-level scanning tool to consider.
Best of luck in the hunt!
Old Dec 24, 2018 | 10:50 AM
Im50fast's Avatar
Im50fast
I was literally about to post the same question.
Im going with the Blue something recommended by chrisFix.
I’ll let you all know what I think after using it a few times.
Old Dec 24, 2018 | 08:03 PM
maticuno's Avatar
maticuno
My SCT X4 tuner is my current scan tool!
Old Dec 25, 2018 | 06:45 AM
Im50fast's Avatar
Im50fast
i have one too. But it’s programmed for one vehicle but I have multiple.
Will it work like that? : can I plug it into any of my vehicles to check codes / misfires?
Old Dec 25, 2018 | 06:46 PM
maticuno's Avatar
maticuno
I haven't tried it yet, but I think it will work with multiple vehicles, it just can't flash the ECU on more than one.
Old Dec 26, 2018 | 08:02 AM
super 6.8's Avatar
super 6.8
I've used my Truck's 5 Star tuner to check / reset codes on many vehicles. It's a decent scanner.
Old Dec 26, 2018 | 10:02 PM
Beechkid's Avatar
Beechkid
Old Dec 27, 2018 | 05:30 AM
JWA's Avatar
JWA
Originally Posted by Beechkid
This is indeed worthy of consideration---at under $200 it's not a bad first introduction into tools of this nature. Found this YouTube video review for the brand and this model:
---impressive for the money to be sure!
Thanks BeechKid for the advice!
Old Dec 27, 2018 | 10:20 AM
maticuno's Avatar
maticuno
I have the C-Reader 8001 model from that brand. It works quite well and is what I used to finally diagnose a bad PCM on my F-250 before I had purchased the tuner.
https://www.amazon.com/LAUNCH-Creader-Scanner-Functions-Diagnostic/dp/B01N36W561/ref=sr_1_9?ie=UTF8&qid=1545927432&sr=8-9&keywords=launch+creader https://www.amazon.com/LAUNCH-Creader-Scanner-Functions-Diagnostic/dp/B01N36W561/ref=sr_1_9?ie=UTF8&qid=1545927432&sr=8-9&keywords=launch+creader
Old Dec 28, 2018 | 04:49 AM
JWA's Avatar
JWA
Also a nice scanner---I'm sure the oil system and brake resetting function would be very helpful.
While we're on this topic anyone here using FORScan? I'm about to begin using that, bought what's supposed to be the ultimate ELM327 interface along with a Dell Lattitude laptop newly loaded with Win10.
Just interested if its as great as I've read so far.
Old Jan 6, 2019 | 06:48 PM
eddienelson
Out of the 2 which on is the most user friendly?
Old Jan 6, 2019 | 10:42 PM
Beechkid's Avatar
Beechkid
IMHO, the bluedriver but only for the reason that if you don't have access (including online which is available through a variety of sources including Helms for as little as $10 for 1 vehicle) to the oem service manual...the description says it will also reference "Free vehicle-specific Repair Reports drawn from a database of over 6.6 million fixes verified by certified auto mechanics"...… otherwise I would go with the other unit.
Old Jan 6, 2019 | 10:47 PM
ford390gashog's Avatar
ford390gashog
Ford under 15.00 I would use the Torque Pro app and a ELM327, for 70.00 get a bluetooth adapter and uses forscan which is almost identical to ford IDS. All the readers above are way over priced.
