Surging idle, dying, won't idle good etc
Old Jun 18, 2008 | 11:41 PM
icrman's Avatar
icrman
A cure if you have idle problems. It would not have done a bit of good to try to clean the IAC valve. First thing I did was check the resistance of the coil. There was none. Meaning it was burned out ie. had an open. Replaced it with an older version I had, and it runs great. So with suspected Idle air control valve problems make sure to check that the solenoid windings are okay first. Just thought I'd share this.
Old Jun 24, 2008 | 11:48 PM
gbrewer's Avatar
gbrewer
you mentioned cleaning the iac valve, how do you clean this part correctly?
evansz95
Apr 16, 2014 11:29 PM
mark227
Jan 1, 2012 09:56 AM
luketrot
Sep 18, 2010 05:47 PM
neb0244
18
Sep 2, 2010 04:06 PM
bjboyle
1997 - 2003 F150
Mar 11, 2004 10:43 PM
