Modular V10 (6.8l)
V10 sucking noise and loss of power when driving only
Old 01-09-2019, 10:57 PM
Goodstuff's Avatar
Goodstuff
Goodstuff is offline
I have a 2000 F250 V10 4X4 4 door Lariat lifted with 35's and 72k miles on it. Have had it for 3 years, since 56k and as long as I've had it I've noticed an intermittent whining/sucking sound and loss of power, but not often enough to cause me any issues. Yes, I have replaced my plugs with new motorcraft ones and torqued them down shortly after buying it so I'm guessing it may be a vacuum issue or leak somewhere. The interesting thing is that It is much more noticeable, as is the power loss, when driving up to and at elevation. Anyone have a similar issue or experience? Since it only does it under power, I can't replicate the sound when parked. Another interesting thing is that when I give it more gas it goes away. Anyways any help will be appreciated. Thanks fellas
edit: When I first got it I did Take it to Earnhardt Fords service department and payed for a mechanic to look it over, no engine codes
Old 01-10-2019, 12:37 AM
maticuno's Avatar
maticuno
maticuno is offline
When it's making the sucking sound under power, does the HVAC switch to blowing from the defrost vents? If it does, that's a pretty sure sign of a vacuum leak.
Old 01-10-2019, 08:13 AM
johnfist's Avatar
johnfist
johnfist is offline
Check your intake filter and the connections where your intake meets the filter box, and the manifold. If everything looks good there, you're probably losing vacuum somewhere. See if the truck does the same thing in park revving it up as well. Would make it easier to find also.
Old 01-10-2019, 10:00 AM
Goodstuff's Avatar
Goodstuff
It only does it under power/while driving... cannot recreate the noise while parked
Old 01-10-2019, 10:18 AM
Goodstuff's Avatar
Goodstuff
I just drove it around and could not tell any difference in the HVAC system when it makes the noise
Old 01-10-2019, 10:21 AM
Goodstuff's Avatar
Goodstuff
could it be throttle body related? I was thinking of pulling it, cleaning it, and replacing the gaskets
Old 01-10-2019, 10:24 AM
Goodstuff's Avatar
Goodstuff
would it be an ordeal to go through and locate a leak in the vacuum system? or is that just replacing the hoses? thanks
Old 01-10-2019, 11:06 AM
johnfist's Avatar
johnfist
johnfist is offline
Seems unusual that you can't replicate it simply by revving the engine while parked, also since your HVAC isn't jumping to defrost it's not really likely its a vacuum problem. Hard for me to guess as I'm just a DIYer. Inspect filter? Inspect/replace fuel filter?
Lot of people have issues with fuel pumps, might be worth getting the fuel pressure checked. I know I've read a few threads where they would have fine pressure while sitting/revving but lost pressure while driving/towing.
Old 01-10-2019, 08:23 PM
Goodstuff's Avatar
Goodstuff
thanks johnfist yes it is odd, I will look into those fuel pump threads
Old 01-14-2019, 02:46 PM
Goodstuff's Avatar
Goodstuff
https://youtu.be/EtXZbSA01ko
I wasn't able to post the video here so here's a link. I am wondering if it's coming from the headers as my mechanic friend said they look like they are leaking. The sound is coming from the driver side I think but the right side has 2 broken exhaust manifold bolts busted off. Could it be as easy as new headers? Maybe the metal gasket is acting like a reed and causing sound with the leak?
Old 01-14-2019, 03:00 PM
johnfist's Avatar
johnfist
johnfist is offline
I would think if it were exhaust you'd be able to hear it without driving down the road. Also, a minor exhaust leak wouldn't cause a loss of power.
sklinck1
1999 to 2016 Super Duty
16
12-04-2017 01:07 PM
wildsman01v10
Modular V10 (6.8l)
05-12-2013 05:28 PM
Arctic Fox
2009 - 2014 F150
03-14-2011 12:40 AM
leviticus
Modular V10 (6.8l)
09-08-2007 06:59 PM
bronco351
09-11-2003 10:16 PM
Quick Reply: V10 sucking noise and loss of power when driving only
