V10 sucking noise and loss of power when driving only
I have a 2000 F250 V10 4X4 4 door Lariat lifted with 35's and 72k miles on it. Have had it for 3 years, since 56k and as long as I've had it I've noticed an intermittent whining/sucking sound and loss of power, but not often enough to cause me any issues. Yes, I have replaced my plugs with new motorcraft ones and torqued them down shortly after buying it so I'm guessing it may be a vacuum issue or leak somewhere. The interesting thing is that It is much more noticeable, as is the power loss, when driving up to and at elevation. Anyone have a similar issue or experience? Since it only does it under power, I can't replicate the sound when parked. Another interesting thing is that when I give it more gas it goes away. Anyways any help will be appreciated. Thanks fellas
edit: When I first got it I did Take it to Earnhardt Fords service department and payed for a mechanic to look it over, no engine codes
Seems unusual that you can't replicate it simply by revving the engine while parked, also since your HVAC isn't jumping to defrost it's not really likely its a vacuum problem. Hard for me to guess as I'm just a DIYer. Inspect filter? Inspect/replace fuel filter?
Lot of people have issues with fuel pumps, might be worth getting the fuel pressure checked. I know I've read a few threads where they would have fine pressure while sitting/revving but lost pressure while driving/towing.
https://youtu.be/EtXZbSA01ko
I wasn't able to post the video here so here's a link. I am wondering if it's coming from the headers as my mechanic friend said they look like they are leaking. The sound is coming from the driver side I think but the right side has 2 broken exhaust manifold bolts busted off. Could it be as easy as new headers? Maybe the metal gasket is acting like a reed and causing sound with the leak?
wildsman01v10
Modular V10 (6.8l)
05-12-2013 05:28 PM
Arctic Fox
2009 - 2014 F150
03-14-2011 12:40 AM
leviticus
Modular V10 (6.8l)
09-08-2007 06:59 PM
