Easiest way through firewall
Old Jan 9, 2019 | 05:00 PM
britdog's Avatar
britdog
Hi Folks,
New to your boards and happy to be here. I have a 2018 F250 6.2L Gas and need to run a wire for a satellite antenna puck from the infotainment head unit out to mount it on the engine cover just in front of the windshield. Looking for any advice, photos, etc. that would help me find the easiest way to run the thin wire through the firrewall.
Thank you!
Old Jan 9, 2019 | 05:12 PM
Mlambert22's Avatar
Mlambert22
There is a large rubber grommet on the drivers side back up behind the parking brake that worked well for me
Old Jan 9, 2019 | 05:57 PM
Tom N OH's Avatar
Tom N OH
Yup, that's the easiest/best place to get to. There's one on the passenger side of the firewall too but, it's a bear to get to it.
Old Jan 9, 2019 | 06:10 PM
britdog's Avatar
britdog
Thank you both. Did you have to cut the grommet/boot at all, or were you able to just fish your wire right through?
@Mlambert22 Nice rig and 5th wheel. I bought my F250 to haul a Northstar popup truck bed camper. Also new to RVs, but learning fast. The 5th wheel is on my list after retirement. Probably look to go to the diesel at that point.
Old Jan 9, 2019 | 06:27 PM
Tom N OH's Avatar
Tom N OH
Just cut a small X in the grommet & push the connector on the end of the antenna cable through.
Old Jan 10, 2019 | 07:20 AM
Mlambert22's Avatar
Mlambert22
I pried the edges of it with a screwdriver and fished it thru the side this time, on my '12 I made a slit.... both times was to fish a couple wires and air line for my on board compressor.. then I put a some filler and silicone to seal it up and made sure nothing was on the sharp edges
Old Jan 10, 2019 | 08:06 AM
bittondb's Avatar
bittondb
There are four circuits on the passenger side that Ford provides for customer use. Take a look at this video. The guy sets up high idle using an upfitter switch and those passthrough circuits. Don't penetrate the firewall unless you absolutely have to.
Old Jan 13, 2019 | 08:40 AM
britdog's Avatar
britdog
Thanks for all of your advice! I ended up running it through the grommet behind the parking brake. Had cut off more of that little nipple than I wanted to, but it's stil pretty snug. I'll probably drop some silicone sealer in there to be sure.
Old Jan 13, 2019 | 08:50 AM
F350 1990's Avatar
F350 1990
50% of ALL vehicles on the road today have rodent nests (majority don't even realize it) so I'd double up insulation, caulking, etc anywhere you go thru that firewall...............
Old Jan 13, 2019 | 11:44 AM
britdog's Avatar
britdog
Ugh! Definitely will do. Thanks!
pacnorwest
6.7L Power Stroke Diesel
Aug 27, 2016 08:55 PM
Go Aweigh2452
19
Sep 23, 2005 12:39 AM
LightMyCigar
Jul 22, 2004 09:24 PM
mpil1
1983 - 2012 Ranger & B-Series
Oct 6, 2003 10:23 AM
