Cracked Frame under steering box
Old Jan 8, 2019 | 11:11 AM
JDFan4010's Avatar
JDFan4010
My new to me 1967 F250 has a crack just under the pitman arm, it runs the entire width across the lower part of the c channel in the frame. My thought is to have it welded and plated, anything else I should do?
Old Jan 8, 2019 | 04:34 PM
FuzzFace2's Avatar
FuzzFace2
Do a search in here and in the 73-79 area for the same issue, cracked frame, to see what all they did for a fix.
They way I look at it the more information you have the better.
Dave ----
Old Jan 8, 2019 | 06:29 PM
JDFan4010's Avatar
JDFan4010
Just talked to my local shop, said they can fix it. One of the guys there has 35 years experience and has repaired a few "back in the day"
Old Jan 9, 2019 | 01:23 AM
GreyScar's Avatar
GreyScar
I wouldn't let Them Touch with a 10 Foot Pole with a Reply like that. It can be Fixed by any Jack Leg putting some slag over it.But if you wont it done right Strip Off everything own the Frame Rail at Least 10" before and Aft and Grind it out and back it up.
Old Jan 9, 2019 | 12:05 PM
JDFan4010's Avatar
JDFan4010
Based on how they described the resolution that's what is being done. I just didn't go through all the trouble of stating exactly what the repair would entail...Maybe I should have.
Old Jan 9, 2019 | 12:08 PM
GreyScar's Avatar
GreyScar
You may be OK then.
Old Jan 9, 2019 | 12:24 PM
JDFan4010's Avatar
JDFan4010
Thumbs up
You may be OK then.
He was talking about a "fish plate" looked it up on "The Google" and it looked and sounded good to me. Hope your right.
Brkdncr
17
Mar 20, 2017 11:32 PM
do49
Dec 30, 2006 12:16 PM
89f150mike
Jul 11, 2006 09:01 PM
f150lariat
Apr 7, 2005 08:26 PM
kylefort
Jan 15, 2002 12:45 AM
