Steering Swap
Old Dec 21, 2018 | 04:15 PM
Tex51's Avatar
Tex51
Steering Swap
I want to go to my local junk yard and strip the steering column, power steering gear box and power steering pump and all the hoses and bring them back and put this on my 69. This set up since I get all of it does it matter about the year model. I might get it from a 2016 or 1999 model I wont know till I get there and find a complete set up.
Old Dec 21, 2018 | 06:03 PM
RichS2659's Avatar
RichS2659
Anything other than up to 79 means you will have to weld and fabricate mounts, brackets, and hoses. It is NOT bolt on. Can you weld and fabricate, or have a buddy who can? Anything else means $$$$.
Old Dec 21, 2018 | 07:51 PM
Tex51's Avatar
Tex51
Ok, Thanks for the info. I can weld and fab and I also have a tig welder but did not want to get that involved, so stay 79 and down and I should be ok. Some of the 79 and down did have tilt wheel and that is primarily what I was looking for. I don't care for cruse control but I will be putting a custom steering wheel on the donner column. I see that when I put the 390 back in I will be dealing with some clearance problems with the headers.
Old Dec 22, 2018 | 03:42 AM
GaryKip's Avatar
GaryKip
The header clearance problem MAY show up, but it depends- are you going with shorties, mid-length, or full-length? I think Hio Silver used the Sanderson FF-427 model and it worked fine. You can either search for his build or check the "Read This First" stickey note and find the article about headers.
Old Dec 22, 2018 | 04:42 AM
Skip1970's Avatar
Skip1970
it be so easy it should be sleezy, i like putting the gm pumps in the saginaw.
Old Dec 23, 2018 | 09:52 AM
awsmev's Avatar
awsmev
also irrelevant
Old Dec 23, 2018 | 11:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by awsmev
I have a 77 junker that I bought for the driveline for my 67. It has a tilt steering. Will that bolt up? That would be a bonus!!! PS box too? ��
Tilt steering wheel introduced in 1978 F100/350, Bronco & Econoline.
Old Dec 23, 2018 | 11:16 AM
awsmev's Avatar
awsmev
Irrrelvant
Old Dec 23, 2018 | 12:27 PM
Tex51's Avatar
Tex51
I will be using long tube headers.
Old Dec 30, 2018 | 07:01 PM
JEFFFAFA's Avatar
JEFFFAFA
Don't forget the pump mounting brackets and the different pulleys. 1976 last year for 360/390. So I would look for 1976 and older there. As of 1978 Ford changed to the CII pump. Adapting it's backet to the older brackets may not be easy.
Old Dec 31, 2018 | 12:28 PM
NumberDummy
The C-II pump is a different shape and smaller in diameter than the Ford/Thompson pump, so the 1977 and earlier brackets will not fit.
The C-II also has a plastic reservoir, the P/S pressure hose attaches to the pump w/a qwik connect fitting.
Old Jan 9, 2019 | 01:36 PM
JEFFFAFA's Avatar
JEFFFAFA
Agreed. That's why I mentioned the pump bracket would have to be fabricated. I know this can be done. My buddy has a 1973 Highboy with a 360. His truck's PO had adapted a CII pump to his 360. It's on there still. The truck is in Camp Verde Arizona and I am not. So I can't get any pics off it right now. He has an old flip phone. Can't send me any pics either.
zombiesawyer
Feb 2, 2010 04:37 PM
blazer350
Oct 20, 2008 05:28 AM
bwallen
Jul 12, 2003 10:49 PM
2 sixes4fun
Apr 10, 2003 08:53 AM
trixie
May 18, 2002 09:03 PM
