Heater help!
Old Jan 5, 2019 | 11:38 PM
Bradyritchie's Avatar
Bradyritchie
Originally Posted by Tedster9
One thing to look at generally is the large electrical pin block connectors through the firewall, these will be corroded all to hell unless somebody has given them some special attention. Try a brass bore brush and kerosene.
i will check and clean those
Old Jan 5, 2019 | 11:44 PM
Bradyritchie
No brown wires. There is one in the gauge harness but it has the wrong connector, isnt hot, and its on the far left
Old Jan 6, 2019 | 04:15 AM
Crop Duster's Avatar
Crop Duster
Heater
Here is a pic of a harness with the brown wire to the heater switch. It should come out of the wire bundle near the yellow/black wire for the radio.
Old Jan 6, 2019 | 10:07 AM
AZSCAWPION's Avatar
AZSCAWPION
A few days ago, my heater stopped working as well as my cigarette lighters (although I think they call 'em phone chargers nowadays). After going through things step by step, I was left scratching my head. Everything checked out. Even more confusing was that they don't share the same wiring. Long story short, it turned out being the contacts on the fuse block. Just enough oxidation/corrosion was all that was needed to cause trouble. So, while the fuses were good, nothing worked. While this doesn't seem to be your problem, it just shows how important good contacts, grounds etc are. Tedster is constantly reminding us about new wires, rust free, clean metal contact etc and I absolutely agree. Even here in AZ, where we only read about rust.
Old Jan 6, 2019 | 12:10 PM
Tedster9's Avatar
Tedster9
Looked at the schematic for my '64 and there is only a single pin junction block connector for the blower, a couple splices, and the switch itself, later years are probably similar. It's worth looking at. Make sure the ground cable to firewall is installed, and tight. And yeah, the fuse block contacts can be shined up with a pencil eraser or whatever. Those blowers draw about 5 amps.
katzklaw
17
Jan 7, 2017 11:05 PM
Frost29
Nov 14, 2012 12:06 AM
ford0625
Jan 4, 2010 12:02 PM
Bookman
Nov 30, 2007 05:00 AM
johndeere75
Apr 4, 2007 05:53 PM
