Sponsored by: Real Truck
heater blower not working
Old Apr 3, 2007 | 09:56 PM
johndeere75's Avatar
johndeere75
Question heater blower not working
its a 99 f250 sd and somtimes the heater blows and somtimes it dosent. with the fan switch on it will blow like normal for a while then go off and on whenever. i think the fan motor works fine but am not sure. when its not working somtimes kicking the bottom of the heater box makes it work. is thisa common problem? is their an easy fix? any help would be great. the truck has 130,000 miles on it
Old Apr 4, 2007 | 08:23 AM
msgtg's Avatar
msgtg
I'd look at the switch...or look for a loose wire connection.
Old Apr 4, 2007 | 05:46 PM
johndeere75
isint some of the heater stuff vaccume controlled?
Old Apr 4, 2007 | 05:53 PM
johnnysF350's Avatar
johnnysF350
When the blower motor actually runs, is it good and strong on the high setting. If it is weak, then it is more than likely the motor on its way out. They will operate weak or intermittent when they are toasted. Changed many of them in CV's with the same symptom. You access them from right under the hood, real easy to change. The only problem you might have is that on the newer motors there was a running change to the plug connector requiring you to get an adapter from Ford. They charged almost as much for the adapter as they did for the freakin motor. Not sure if this applys to the SD though, but probably, because alot of those type items are used across lines.
rvpuller
Ford In-Vehicle Tech
Oct 8, 2013 09:35 AM
alvald83
Nov 20, 2010 09:35 AM
00GT
May 21, 2007 04:57 PM
trucker41
Nov 24, 2002 07:23 AM
luxury 4x4
1978 - 1996 Big Bronco
Dec 20, 2001 09:33 PM
