Started my truck this morning and went to back out of my driveway and noticed my backup camera is not displaying an image. Drove to work and backed into my spot and there was still no image, but the alert sensors are still working for when you get too close to something.
I have a 2019 F250 and have only had it around 2 months. It went down to around 25 degrees last night but it has been pretty cold the past few weeks with no issues. Any idea of what the issue could be?
Yeah its more of a grayish color but completley blank
I had the same issue the other day, neither rear camera would come up. I shut off the truck and opened the door so it would shut down completely. Then I restarted the truck and the image came back. I have not had it happen again.,
Thanks for the reply. I’ll try it again when I leave work in a few hours.
Just went out to check and its working fine now. I had this same issue with the radio in my 16 F150, so I should of known to shut it off and try it again.
I had this happen to my truck shortly after I got it. It would work on rainy/wet days, and not work when it dried out. The dealer found a bad pin in one of the connectors on the harness. They fixed it and it's worked flawlessly since (4 months)
My 2012 would get real grainy super light, like it would almost resemble a thermal image camera, when it would get real cold, like -10 cold, i always thought it was some moisture in the connector or the grease froze.. it never consistently did it so I never got it looked at and other than when it was super cold would work flawlessly
It hasn't been that cold with this one, yet...
