Vacuum guage
Old Jan 2, 2019 | 12:10 AM
1957 F100 New Guy's Avatar
1957 F100 New Guy
Vacuum guage
Did Ford make an in dash vacuum guage for a ‘57 f100, or one that would fit in the dash?
Thank you for the help.
Old Jan 2, 2019 | 01:02 AM
Tedster9's Avatar
Tedster9
There are lots of aftermarket vac gauges, SW made one called "motorminder" that are colorful and I think even Ford made a gauge then but it would cost a small fortune if you can find one. Short answer though is yes, should be able to find something that will look factory or near enough.
Old Jan 5, 2019 | 02:56 PM
FuzzFace2's Avatar
FuzzFace2
I don't know what a stock one would look like but try http://www.speedhut.com/gauges/
As they say you can build your own gauge from size to back ground, font colors and different fonts.
vacuum gauge page
http://www.speedhut.com/gauges/Boost...id=f232|f2|f32
I had gauges built to replace ones in a car project to look just like the stock one if you looked fast at them.
Then if you took your time to look you would see a 160 MPH speedo and a 4 gauge in 1 that replace the 2 gauge only one.
One of the 2 far right smaller gauges is a vacuum gauge the other is a clock. They are in the same place as the Rally Gauges would be for the car.
The Tach is on the far left where the stock clock was. The 4 gauge was just fuel & temp, now has oil & volts too.
Then again the silver carbon fiber dash over lay also looks like the base line model car one but ........
Dave ----
D.Yaros
Jun 18, 2017 12:30 PM
sweetlou1
37
May 2, 2015 08:00 AM
19fifty4
May 6, 2013 07:02 PM
2New2Fords
Oct 26, 2006 08:18 PM
MatthewC
1978 - 1996 Big Bronco
Sep 9, 2004 03:00 PM
