C-clamps all the way... Well, as long as the overlap joints are good and strong.
I see no problems at all with clamps in place of welding because the overlap is usually 2-3" of pipe and then perhaps a lap clamp. My MBRP came with clamps and slip joints, most aftermarket exhaust kits are clamps with slip joints.
I would spend a little extra and use lap joint or butt joint clamps, either stainless or aluminized steel. These joints hold well and if you ever have to replace or remove the muffler they will allow you to do it without tearing up the exhaust pipe and/or muffler. These clamps don't crimp the metal and will save your sanity in the future, just ask Sous if he enjoyed bending, prying, and cussing when he had to re-engineer his down pipe juncture with the exhaust pipe. I have used them on several vehicles over the years and they are a gas tight, reliable alternative.
I had mine welded in. Possibly the first mod I did to the truck. IIRC the BTM was $48 and the weld labor was $50, lol. There was a bit of the exhaust pipe either before or behind the muffler, an S shape, that was cut off and inverted (up or down not end to end) to make it line up perfectly straight. I had access to a good muffler shop that built a complete, beautiful dual exhaust to accommodate headers on my '75, so it was an easy choice. Plus I hate working on exhausts.
Welding means nothing can come loose. Still waiting for the BTM to rust through so I can have them bend up a 4" setup with a big honkin' FTE resonator.
Had Oreillys come thru with the clamps at 3.59ea. But, with shop(bro work place) closed and my damn sawzall in bullhead, gotta sideline job til mid next week. Its 1st of year and now xmas lights need tore down. Going the, use the clamp to secure for welding, then remove clamps for l99 stock muff re-install
Acquired the btm thru ebay which was a Summit ad. 63.99 std.
Found out more of that S pipe. Cant screw them 2 cuts up or SOL. Will take pics for the viewing audience
Took a month, but her lung can breathe easier. Me and my bro knocked it out and rearend fluid change.. Goin Up Walker with clamps..3.5\" Old muffler out Outlet Cuts made just past welds to save the S section Walkers' new home Amount cut off on inlet side of muffler for correct fit
Maybe 3" I.D. because the walker needed some persuasion to fit on the stock exhaust.
here's what i ordered..little whistle at idle but soinds purdy good getn on it
