1993 Superduty ABS problems
Old Dec 30, 2018 | 01:49 AM
ihaul's Avatar
ihaul
I have a 2wd 1993 ford superduty that is equipped with hydroboost 4 wheel disk brakes. The brakes work great until the ABS light comes on. The light comes on a couple minutes after I get it on the freeway. When the truck is loaded and the road is wet the front wheels will lock up and skid. It seems as if the rear brakes never get used and I am not able to lock them up under any condition. I looked around on the forms and haven't found anyone with this issue. Any one have any suggestions as to what the problem may be?
Old Dec 30, 2018 | 04:34 PM
85e150's Avatar
85e150
Thread moved.
Welcome to FTE.
This forum should provide more help for your truck.
Does it have all wheel ABS or just rear wheel?
Old Dec 30, 2018 | 08:36 PM
ihaul's Avatar
ihaul
Thanks. It has ABS just to the rear wheels.
Old Dec 30, 2018 | 08:56 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
How do your rear brake pads look? Did you loosen the bleeders,step on the brake,to see if they're pumping fluid out? I almost recall seeing one of those load sensors on the rear axle but I don't seem to have a pic of it. If so,I wonder if that's gone buggy on ya,if it's only acting up when you load it.
Old Dec 31, 2018 | 01:40 AM
BS51993's Avatar
BS51993
Could just be a bad sensor. They're prone to failure due to corrosion because of their location especially on Midwest trucks that are regularly exposed to salt.
Old Dec 31, 2018 | 06:59 AM
rla2005's Avatar
rla2005
Pull the RABS codes. On the F-series there is a test jumper located near the glove box. Not sure if your F-Super Duty is in the same location.
Old Dec 31, 2018 | 03:28 PM
TexasGuy001's Avatar
TexasGuy001
You could also try disconnecting the RABS controller behind the glove box and see if the rear brakes work correctly like a non ABS truck. Is the fluid topped off. If the master cylinder is low the light will sometimes come on. The VSS/RABS sensor is on the rear end. A friend had a load sensor on an old Suburban cause problems like this. He just bypassed it.
Old Jan 1, 2019 | 11:57 AM
ihaul's Avatar
ihaul
I know the rear pads look good. I will open the brake bleeders to make sure that fluid comes out.
Old Jan 1, 2019 | 12:00 PM
ihaul's Avatar
ihaul
I will try to locate the RABS controller and disconnect it. The fluid is topped off.
Old Jan 2, 2019 | 01:35 AM
BS51993's Avatar
BS51993
If the master cylinder is low, it will trigger the red "brake" light as well as the anti lock light but he only has the anti lock light.
deankats
Nov 23, 2011 10:50 PM
79shovelhead
Oct 16, 2009 04:42 PM
mjbll
1997 - 2003 F150
May 21, 2009 08:08 AM
JRCF
54
Jan 18, 2008 06:27 AM
kjjm4
1983 - 2012 Ranger & B-Series
Sep 23, 2003 12:53 PM
