Steering column interchange question
Old Dec 28, 2018 | 10:06 PM
1981 F100's Avatar
1981 F100
I am wanting to find a steering column, the style that had the gear selector pointer on the column itself, and not as part of the speedometer as my 81 has.
What other years would work?
Old Dec 29, 2018 | 04:13 AM
Rembrant's Avatar
Rembrant
I don't know what if any factory options exist, but somebody just posted a cheap solution to this problem recently...
https://www.ididitinc.com/c-1310153-...ndicators.html
Installed pics here...
Bullnose Enthusiasts - Hello all. Hope this fall has been good to you so far. Wondering if anyone out can hook me up with a shift selector cable or the whole assembly for a 1985 F 250. It?s an obsolete item at Ford now. Thank you, Tom
For $22 bucks, that's a cheap fix.
Then just get a little blank filler plate from a truck with a manual trans cluster, and you can remove the indicator from your existing cluster. Done like dinner.
Unless of course you are truly seeking a factory solution...
Old Dec 29, 2018 | 10:35 AM
keithbutts's Avatar
keithbutts
The 1975-1991 econoline vans use the same style of column as the 1980-1991 trucks but have the shift indicator on the column, because they still used the 1973-1979 truck gauge cluster. but I do not know how easy they are to swap or if you can.
Old Dec 29, 2018 | 04:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
None.
1979 was the last year, but a 1970's column will not work on a 1980's truck.
Old Dec 29, 2018 | 06:45 PM
keithbutts's Avatar
keithbutts
But what about the econoline columns or are they two different lengths.
Old Dec 29, 2018 | 07:19 PM
1981 F100's Avatar
1981 F100
Ok thank you for the info
Old Dec 31, 2018 | 12:21 PM
NumberDummy
Econoline column is completely different, will not work in an F series truck.
Sep 26, 2023 02:47 PM
Gwilkrrs
Dec 11, 2018 06:52 AM
78 PEB
Jul 12, 2016 02:25 PM
My9fam
Dec 16, 2012 10:42 AM
Bigdaddy29384
Feb 11, 2005 05:11 AM
