steering column measurement
Old Dec 15, 2012 | 10:49 PM
My9fam's Avatar
My9fam
Unhappy steering column measurement
Hi,i recently removed my original steering column on my 65 f100 .I am going to replace it with an aftermarket tilt that has a chevy style plug,im also going to rewire the whole truck. I sold my original column along with the steering wheel. My question is,Does anybody know how long the original column measures without the steering wheel?The column i want to buy comes in 28" 30" or 32" length.I am trying to match the length of the original .Thanks
Old Dec 15, 2012 | 11:10 PM
Shadowrider123's Avatar
Shadowrider123
I do not know but nearly everyone wishes that the orginial column was shorter.
Old Dec 15, 2012 | 11:55 PM
vincel1965's Avatar
vincel1965
I am also replacing my original column with an aftermarket (ididit p/n #1130820020) column. I spoke to ididit directly and was told this series is a direct bolt in. My original column is still in but should be pulled within the next week or so and can measure for you if you still need. If it helps I can measure from the floor board to the steering wheel? But not until Monday.
Old Dec 16, 2012 | 12:45 AM
My9fam's Avatar
My9fam
Thumbs up steering column
If you can measure your column that would be of great help.i just need the column measurement .if posible the whole column.Thnks for your help
Old Dec 16, 2012 | 01:00 AM
Shadowrider123
On a 67-72 truck which is the same as a 65-66, the manual steering shaft is 35 5/8in. The ps shaft is 32 7/8in, the difference being that the saginaw steering box is longer than the manual box.
http://www.fordification.com/tech/powersteering.htm
Old Dec 16, 2012 | 10:42 AM
My9fam's Avatar
My9fam
Smile steering column
Thanks for the info,sounds like i need a 32 inch aftermarket column,its closer to what i had.i had installed the sawginaw box so it was a little to close to the seat.I think the aftermarket column can be adjusted and with the mustang type suspension i had installed it should give me enough room .thanks again
Mr08353
1997 - 2003 F150
Oct 18, 2017 08:26 PM
Darrellt
May 22, 2017 12:57 PM
78 PEB
Jul 12, 2016 02:25 PM
fatfenders
18
Sep 18, 2003 09:15 PM
