tilt steering column quesrtion
Old Dec 9, 2018 | 08:14 PM
Gwilkrrs's Avatar
Gwilkrrs
I have a 51 f1 and need a tilt column. what length is correct? I want a tilt column with column shift key or no key
is the ididit column worth the big price tag or is the summit column just as good for half the price?
Old Dec 10, 2018 | 06:08 AM
drptop70ss's Avatar
drptop70ss
Find out who makes the column summit sells or ask them if the internals are plastic or metal. There are articles on the web about cheaper offshore columns having plastic knuckles that fall apart and could cause loss of steering.
I stick with factory columns, cheap and no worries about losing steering.
Old Dec 10, 2018 | 06:19 AM
Gwilkrrs's Avatar
Gwilkrrs
do you source new factory columns or used?
do you know the make/model or length for an f1 cab?
thanks
Old Dec 10, 2018 | 06:58 AM
drptop70ss's Avatar
drptop70ss
I use different columns for different applications, and sometimes I modify the columns. What I do is get the seat in the vehicle, use a broomstick with a mock steering wheel on it and get the wheel where you want it. Measure how long the broom stick is and you have your length. Length you can use depends on clearances in the engine compartment, what steering setup you are using and if it is a column shift or floor shift vehicle.
Also my columns are all swap meet items, so I am not always sure what they came from, only general year range. Truck #1 I have a 1965 olds cultass column, truck #2 I think it is a 70s cutlass column. Lots of pictures in my build threads, and in truck #2 I first mocked up a 70-72 cutlass non tilt and then found a tilt at a swap meet.
Old Dec 11, 2018 | 06:52 AM
GreatNorthWoods's Avatar
GreatNorthWoods
It has been a while since I built my 49 F-1 but as I remember 32 inches was the column length.
Sep 26, 2023 02:47 PM
78 PEB
Jul 12, 2016 02:25 PM
My9fam
Dec 16, 2012 10:42 AM
1978 Big 6 F250
Feb 8, 2004 06:47 PM
