Expy wouldn't start
Old Dec 28, 2018 | 09:27 PM
Robert Clegg's Avatar
Robert Clegg
Expy wouldn't start
Hello new member, 04 expd 5.4. Truck has been running great ,sat for a couple of days because of christmas. Long story short ,tried to start it up it cranked over just fine but wouldn't start. After a little googling saw a video about inertia switch , pressed it and it started right up!! Does anyone know why that would trip?
Thank you in advance for any suggestions.
Old Dec 28, 2018 | 09:44 PM
Sam I Am's Avatar
Sam I Am
Maybe someone pranked you.
Old Dec 30, 2018 | 09:59 AM
alloro's Avatar
alloro
That switch doesn't "trip" like say a circuit breaker would. Instead it's meant to shut down the fuel pump in the event of a rollover. So for the switch to "trip" it would have to be turned upside down. If it happens again I would replace it.
Old Dec 30, 2018 | 11:40 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by alloro
That switch doesn't "trip" like say a circuit breaker would. Instead it's meant to shut down the fuel pump in the event of a rollover. So for the switch to "trip" it would have to be turned upside down. ....
I've read reports where a pot hole or curb strike can cause the switch to trip.
I thought the switch responded to a shock - https://en.wikipedia.org/wiki/Inertial_switch
Old Dec 30, 2018 | 12:15 PM
alloro's Avatar
alloro
Makes sense to me since such a jolt would cause a reversal a gravity for a few 10ths of a second as the truck goes up then down.
Old Dec 30, 2018 | 09:37 PM
projectSHO89's Avatar
projectSHO89
It's an impact-sensitive switch that is supposed to "trip" (like a circuit breaker!) when physically shocked. You should be able to trip it with a very firm slap to the panel where it's mounted.
Back in my SHO days, I had a tool box in the trunk of the ole '89. I went around a corner a bit too fast causing the toolbox to slam into the side of the trunk where the inertia switch was located. Had to coast to the side of the road, get out, open the trunk, and reset the switch to continue down the road.
RubyRed350Platinum
Feb 24, 2022 07:36 PM
scharles1968
May 3, 2013 06:00 PM
60RatRod
21
Apr 28, 2009 09:34 PM
Spamjohnson
Apr 23, 2007 03:06 PM
kormelistdijetta
1983 - 2012 Ranger & B-Series
13
Jun 26, 2006 01:40 PM
