1978 - 1996 Big Bronco
What does this mean?
Old Dec 26, 2018 | 08:37 PM
Aaron_Jones's Avatar
Aaron_Jones
New to Broncos, I just picked up a Ford Bronco and I did a Vin decode and it gave me this motor:
8 Cylinders H 5.8L FI
Is this a Winsor?
Old Dec 26, 2018 | 08:48 PM
1985 Bronco's Avatar
1985 Bronco
Originally Posted by Aaron_Jones
Is this a Winsor?
It's a Windsor! (assuming it is the one in your signature).
Old Jan 18, 2019 | 06:54 PM
13mm's Avatar
13mm
351w & 5.8l are ford small block "WINDSOR" engines, "H" in vin code is supposed to be a block designation for a roller tappet camshaft in bronco, 1994 is probaly the starting year.
good luck may you well!
13mm
Old Jan 23, 2019 | 02:13 PM
rla2005's Avatar
rla2005
Completely false. The 8th position of the VIN does indicate which engine was in the vehicle when it left the factory. But it does not designate whether or not it is a roller block.
In the OP's scenario the 8th position is H which designates a 5.8L Windsor engine, that's it.
Straight from the Ford service manual:
mrjeepin82
Mar 16, 2018 11:47 AM
CharlieLed
Nov 9, 2014 10:34 PM
jaimalade
Jul 12, 2003 07:32 PM
g.watson
23
Feb 26, 2003 11:55 PM
82F100SWB
Jan 18, 2001 09:46 PM
