1978 - 1996 Big Bronco
Funny problem after disconnecting battery
Old Jan 12, 2010 | 03:48 AM
coalrollinf350's Avatar
coalrollinf350
Hey there, I have kind of a weird problem. The other day I replaced the battery in my 95 bronco and go to start it and no go. I thought maybe its the alarms immobilizer but found out it cuts power to the starter and not ignition. It cranks and cranks with fuel (I can smell it very strongly) and what appears to be good spark. I am stumped, is it possibly the ignition module may be at fault? It appears to be original but why would it all of a sudden go bad from replacing the battery. Any thoughts would be greatly appreciated! Thank you
Old Jan 12, 2010 | 05:08 AM
b4hntn's Avatar
b4hntn
Welcome to FTE. I'm sure everyone will do their best to help you.
My first guess would be grounds. On my '94 the pigtail ground off the battery connects to a ground post on the fender along with two wires. That post was turning in the fender and the nut was not down tight creating a loose connection and intermittent dying. I ended up making a new ground next to it with a bolt.
Old Jan 12, 2010 | 10:06 AM
Encho's Avatar
Encho
The Southernmost Mod
Maybe the starter relay isn't working anymore, it's a common problem, try jumping it by making a connection between the two bolts that come out of it and see if the engine turns. If if does, then the relay is gone.
Old Jan 12, 2010 | 11:10 AM
coalrollinf350
Thanks for the replys! The engine is turning over with spark I even tryed liquid start with no go. I am definatly positive it is an ignition problem but It has spark at all the plugs. Whether or not it is a strong enough spark im not sure. Do you think the ignition module may have just gone bad when I finished replacing the battery? It would be weird but im not sure what else it could be.
Old Jan 12, 2010 | 11:52 AM
coalrollinf350
Ok I have narrowed it down to a weak spark. I went to check the timing and the light wouldn't pick up the spark very well. I am just wondering what would cause an all of a sudden weak spark, could it be the ignition module or the coil. The truck was running great the day before.
Old Jan 12, 2010 | 02:54 PM
coalrollinf350
It was just the coil, its running like a top now! Fairly cheap fix too.
Old Jan 12, 2010 | 04:13 PM
greystreak92's Avatar
greystreak92
Sorry we weren't able to get you more info faster. Glad you got it fixed. Any electronic device with a coil in it is subject to sudden (and apparently without good reason) failures. Alternators, ignition coils, any sensor with a variable resistance coil inside, blower motors... they all fall into the category of "coils" and unfortunately can fail with no warning.
Old Jan 13, 2010 | 04:18 AM
coalrollinf350
Yeah I was too quick and needed this thing runnin again! No doubt about coils, I cant beleive it died right after disconnecting the battery, weird.
Old Jan 13, 2010 | 07:52 PM
greystreak92
It could have had a weak coil that would have held up for many more miles and the inrush current killed it when you reconnected it. Hard to tell.
Old Jan 28, 2019 | 11:36 AM
combat-24's Avatar
combat-24
2013 f150 110000km
same problem stuck in 5th dash goes dead is it the leadframe as I'm talking to ford now about and have to pay myself 5 year old truck should not be doing this
