Constant Voltage Regulator
Old Dec 26, 2018 | 03:47 PM
skbradsh's Avatar
skbradsh
Hello everyone. I am new to the forum. I recently started reviving a 62 f350 that was left in the barn of the property I purchased. At this point I have made some progress but I am having trouble with the fuel and temp gauges. The manual says the constant Voltage Regulator must fluctuate between 0-10. Mine remains steady at 12. Does it have to fluctuate? The fuel gauge will have to be replaced the bi-metal has burned in two. The temp goes straight to hot when the key is cut on. I think this would indicate a grounded circuit but i have ran new wire and still have the same issue. I have included a picture of the back of the gauge cluster does anyone know what the coil is on the voltage regulator? Does it knock the voltage down? Would a bad gauge cause this problem?
Old Dec 26, 2018 | 04:34 PM
1960fordf350's Avatar
1960fordf350
Nice truck. Love the patina!! I'm OK with basic electrical issues, I've never dealt with gauges. I'm sure somone will be along to help with that. Did you change tires? Looks like good tread on em.
Old Dec 26, 2018 | 04:42 PM
skbradsh's Avatar
skbradsh
I put new tires and tubes on it. I found a localish tire store that would install them. Future plans may include new rims or new axles. What did you do for your tires?
Old Dec 26, 2018 | 05:17 PM
User 71024's Avatar
User 71024
Your cvr is NG. Guages are low voltage they wont run on 12v.
Old Dec 26, 2018 | 11:24 PM
Christmas's Avatar
Christmas
Whats that white thing clipped into the regulator?
Old Dec 26, 2018 | 11:50 PM
The Masked Rider's Avatar
The Masked Rider
Your CVR needs to be replaced or you stand the chance of burning out the gauges. That thing, I assume, is someones attempt to drop the voltage. You can buy a new one from DC or one of the other parts places. Hope your gauges aren't already fried.
Old Dec 27, 2018 | 09:17 AM
skbradsh's Avatar
skbradsh
Thanks for the help. I have ordered a new cvr. The fuel gauge is trash but I hope to salvage the temp gauge. With 3 volts it reads im the middle of the gauge. Do you know what voltage the cvr puts out? Is it 6?
Old Dec 27, 2018 | 10:10 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The ICVR has a bi-metal spring in it that breaks contact when it heats up. By applying 12 V to it the bi-metal spring heats up and breaks contact at about 10V output, then it swings back toward zero. Once the metal contact is broken then it quickly cools back down again and makes contact - beginning to heat up again until it breaks contact. So, it fluctuates rapidly between zero and 10 volts, averaging roughly 5 volts to the gauges.
The newer solid state ICVRs put out a constant 5 volts and no bi-metal spring inside to go bad.
Here's the manual discussing it.
Chad
Old Dec 27, 2018 | 10:15 AM
TA455HO's Avatar
TA455HO
Lead Gopher
One other thing to note - you can't tell much by hooking up a digital VOM to the regulator. The voltage fluctuates so fast the digital meter will be in constant seek mode. To see the movements of the ICVR a person can use an older analog VOM with a needle. The needle is able to move back and forth quickly enough to visually display the fluctuations.
And people thought there was no use for the old analog VOMs any longer.
Chad
Old Dec 27, 2018 | 10:24 AM
Tedster9's Avatar
Tedster9
Analog voltmeters have their uses with primitive electronics and are plenty accurate enough for automotive use. 3 significant digits just ain't necessary. If using points ignition or generator they are optimum for testing and the voltages in the service manuals were made using analog equipment.
Looks to me like that bobbin lookin' deal on the ICVR is a choke or somesuch, connected in series to suppress radio noise as described in the manual. Get a popping noise in radio or CB otherwise.
Old Dec 27, 2018 | 02:43 PM
The Masked Rider
Tedster, you are correct, I remember now what those things were used for. I call it 'the fog' these days. Eventually the light bulb goes on.
Old Dec 27, 2018 | 04:26 PM
Tedster9's Avatar
Tedster9
That's why we're here..
Because we ain't all there!
Old Dec 30, 2018 | 04:08 PM
cosmofennema's Avatar
cosmofennema
Just a couple things.
1) If this were MY truck, I'd get a title BEFORE I did anything on it. Until you possess a title in your name, the truck is subject to repossession.
2) Early Honda GoldWings (all 1000 and 1100 save Aspencade, [which I own]) also used a CVR, though Honda say theirs is 7 volt. Still might be worth looking into.
Cosmo
7oldblue3
Mar 17, 2019 06:28 PM
fancyvern
Apr 17, 2018 07:44 AM
briney
37
Apr 21, 2008 06:31 PM
hiwy50
Aug 30, 2006 07:55 PM
epos48
Electrical Systems/Wiring
Jan 24, 2005 02:09 PM
