6 volt to 12
Old Aug 26, 2006 | 09:12 PM
hiwy50's Avatar
hiwy50
6 volt to 12
Installed 302 of unknown year in 55 panel truck, converted to 12 volts. How do I get guages to work properly? Replaced oil and temp. senders with new 1955 replacements but guages work as if the sending units were a dead short.
Old Aug 26, 2006 | 11:37 PM
mtflat's Avatar
mtflat
You need a voltage reducer/regulator for your gauges. All Fords thru the 70's used one for the gauge cluster. Don't keep them hooked up to straight 12V or you'll fry them. Ford kept gauges at 6V a long time.
Old Aug 27, 2006 | 10:34 PM
SteV8e's Avatar
SteV8e
You need a Runtz voltage regulator, which will convert an input of 8-20 Volts to 6 Volts, one each gauge: FUEL, OIL, TEMP. The ammeter (BATT) is inductive; it passes by the back of the gauge. If you change the direction of the wire, it will read properly. Otherwise, it will read backwards.
Old Aug 27, 2006 | 11:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
...instead of the 3 Runtz's, you can do what Ford did, use a single Constant Voltage Regulator, or CVR, available at NAPA. It feeds all three gauges. Just cut it in to the existing lead to the gauges.NAPA ECHIR1 $24.99
(they list it as an "instrument regulator")
Old Aug 30, 2006 | 07:43 PM
hiwy50's Avatar
hiwy50
Tryed to run all thee guages, fuel, oil & temp. with one Runtz regulator. No change. Will try to run only one guage with regulator tomorrow. Stumping me.
Old Aug 30, 2006 | 07:55 PM
SteV8e's Avatar
SteV8e
Definitely only one Runtz per gauge; you need to keep the circuits separate to function properly. If you try it on one, it should work fine. To test the gauges, apply 1.5 Volts DC across the terminals. Within about 20 seconds the pointer should come to rest at the center of the gauge, or close to it.
lbrauer
Jul 25, 2010 01:03 AM
joefordman
Jul 19, 2008 11:02 AM
jreilly57
Nov 9, 2006 10:00 AM
dads 46
1947 and Older Ford Trucks
Sep 10, 2004 10:13 PM
gblakeney
Oct 11, 2001 06:32 AM
