Sponsored by: Real Truck
Adding remote start
Old Dec 26, 2018 | 09:17 AM
stephen.osborne1's Avatar
stephen.osborne1
Adding remote start
I couldn't find this in the search.... I was reading in the f150 section how One can add remote start to an '11 and newer truck with Forscan and new keys. Is this possible on my '13 PSD? Sounds like the half tons already have the capability built in, just needs to be enabled and the remote start button on the key. Thanks.
Old Dec 26, 2018 | 09:36 AM
wess23's Avatar
wess23
I did so on my 2012 F-350 6.2, bought the module and a new key from a Ford dealer on Ebay for I think a hundred of may a buck fifty and used Forscan to enable it, all very easy. Just looked up the part on my Ebay account, here you go: (assuming links are allowed)
https://www.ebay.com/itm/11-thru-16-...dhSK:rk:1:pf:0
Old Dec 26, 2018 | 12:00 PM
projectSHO89's Avatar
projectSHO89
You need the new key(s) cut, the antenna, the antenna cable extension (optional, allows a bit longer range), and then everything programmed.
The system would work without the antenna but would be EXTREMELY short range, like standing right next to the truck. Useful for troubleshooting or proof of concept, but not much else. Without the extension cable, the antenna is placed under the dash and you can expect 25-100' range. With the extension cable, the antenna gets placed much higher in the cabin and you can expect 100-300' of range.
Old Dec 26, 2018 | 03:04 PM
Just Strokin's Avatar
Just Strokin
If your truck does not have the hood switch, you will need it also. Approx $17.00.
You will need two previously programmed to PASTS keys to program the new remote start key.
If you need instructions, send me a PM. Will email you the install instructions.
Old Dec 26, 2018 | 08:54 PM
projectSHO89
Good point regarding the hood switch. Pretty much anything except stripped down model is going to have it though.
Since you have to use Forscan to enable the remote start function, you automatically have the capability of re-programming the PATS system from scratch thus negating the requirement to have two pre-existing programmed keys.
Old Dec 27, 2018 | 08:21 PM
clarkbre's Avatar
clarkbre
Check out 12volt.solutions. They carry an aftermarket, plug and play kit for the '11-'16 that use your existing keys. All for $249.99
2011-2016 Ford Super Duty Remote Start Plug and Play Kit
Old Dec 27, 2018 | 10:09 PM
Just Strokin
Looking at this kit, I think the Ford remote start kit is a lot simpler to install. The Ford is plug and play with only ONE WIRE HARNESS to hook up. The plug for the hood switch is there if one needs to add it. No drilling to add hood switch nor wires to run through the firewall.
With FORScan, you can program (turn on) the remote start and new keys if you only have one. With the kit you are suggesting, it indicates one needs factory remote rntry fobs, one must acquire remote entry fobs for the door locks to activate the remote start.
Also, the Ford is approx $110 cheaper.
Stephen Fruscillo
2009 - 2014 F150
21
Jul 15, 2020 12:57 PM
scutler83
Jul 13, 2019 08:54 PM
Goranb81
2009 - 2014 F150
Dec 25, 2018 05:20 PM
mattri
2015 - 2020 F150
Jul 9, 2017 06:57 PM
HawaiianStyle
2004 - 2008 F150
16
Sep 8, 2004 09:38 AM
