Help with forscan
Old Dec 19, 2018 | 11:48 AM
Goranb81's Avatar
Goranb81
Help with forscan
So i have been watching videos and stuff about Forscan. I have the spreadsheet printed out already and i'm just a little confused. I'm looking into the remote start feature. Does my 2014 F 150 5.0 already have the remote starter on it from factory and all i have to do is use Forscan to activate it and buy another set of keys with the remote start button on them or do I actually have to add a remote starter to my truck. I'm new to this site and new to this forscan stuff as well. Thanks in advance
Old Dec 19, 2018 | 07:35 PM
jdunk54nl's Avatar
jdunk54nl
It has it built in. You will need the keys and the antenna.
I would buy this:
https://www.ebay.com/itm/11-thru-14-...94eA:rk:3:pf:1
if you want two keys
11 thru 14 F-150 OEM Genuine Ford Parts Integrated Remote Start Key 164-R8067
Old Dec 22, 2018 | 01:17 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I added it to my 2014 as well.
You will need to add the antenna, a "relocation kit" (just a longer wire) and a compatible key. For me, finding a key that was programmable was the hardest part without going to the dealer.
If you have any questions, send me a message and I'll help you sort it out
Old Dec 25, 2018 | 05:07 PM
zxwut?'s Avatar
zxwut?
It'll work with just FORScan and the key. If you want the extended range, you can add the antenna. If you want even further range, you can add the cable to relocate the antenna from behind the glove box to above the headliner console.
Old Dec 25, 2018 | 05:20 PM
ford390gashog's Avatar
ford390gashog
This kit has two keys and the antenna. Just enable in forscan.
Remote start
mattri
2015 - 2020 F150
Jul 9, 2017 06:57 PM
pgguru
Jan 20, 2016 01:42 PM
northernguy
1983 - 2012 Ranger & B-Series
Nov 14, 2011 05:38 AM
BillyBob69
1997 - 2003 F150
Jul 20, 2005 02:33 PM
gmarkie
1997 - 2003 F150
Mar 11, 2003 10:51 PM
