Tailgate Ladder/step?
I think having access to the bed via a step is a great luxury to have for a 4x4 truck.
I agree, the AMP running boards/steps are nice and pretty, but I prefer function over looks everyday of the week. If I can get both at one time with a reasonable price, then that is better.
Thanks again Pete, I always value your opinion and ideas.
When I got my truck some 12 years ago, ,it already had the black Westin cab-length side step bars on it, but like I said. Though probably not the sturdiest, they're sturdy enough to have successfully handled the full load of my 250-270 lb carcass on EVERY entry and exit from the truck for over 12 years now, and still don't sag. They're not the best available, but given the way they've held up, I just can't justify replacing them!
Purchased from Amazon with a 20$ instant coupon at time of checkout. I jumped at it because of the coupon and knowing that I would kick myself if I didn't get it when it was on sale.
Link to step - https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
The Good
1. Would I buy it again? - Yes
2. Am I OK with the price I paid at $155? - Yes
3. Does it work well? Yes, better than expected
4. Does it feel sturdy and well supported when stepping on it? Yes
5. Does it fold up and out of the way of someone walking? Yes
6. The step is adjustable from side to side by about 8" to bring it inboard or outboard more. In the pictures below, I have it at its most outward position and will move it in if I feel the need.
7. The arm/bracket is adjustable and can be lowered another 1.5" or so. Where it is now is almost a halfway point between the ground and the tailgate.
8. Does the step making getting into the bed easier? Yes, immensely easier.
9. Do I feel like I will lose my balance getting into or out of the bed using the step? No, I use the bed side rail as a hand hold going up or down from the bed.
10. Would I get the AMP version of this for ~$210? No
11. Does my wife approve and like the functionality of the step? Yes
The Bad
1. The instructions say 30 minutes with a few tools. That was not the case for me.
2. There is a small "tab" at the corner of the bumper that must be bent up a bit, not a big deal, but that required more tools.
3. The socket sizes required by the instructions were wrong, this was for their own supplied hardware, not the Ford fasteners.
4. The powder coat on the bracket is very good, but the holes/wells where the nut goes back onto the mounting bolts of the truck will not accept the flange nuts because the powder coat takes up a fraction of the space. I remedied this by sanding a bit of the hole/well and grinding a bit of the flange off. I am talking 1/64" or so, nothing major, but it took some time to get it right.
5. Getting the bracket for the arm onto the Ford fasteners which are now inside the hole/well was was a pain in the *** because the threads were not protruding very far into the bracket. In addition, the Ford fasteners and flange nuts hold the bracket for the drivers side rear of the bumper in. They have some tension to them, so getting the fastener through the frame, through the bracket for the bumper, into the hole/well and then a flange nut onto the fastener was a pain in the *** for me. Maybe it is because I was tired from working on the 5th wheel all day.
Pictures
I am looking to do something like you did that will fit to the hitch and not obstruct the turning of the 5th wheel. I think the name is rock tamer or something. I would like to do a homemade version, but I still haven't bought a welder.
EDIT: First thing tomorrow morning I am going to peel off that sticker from the bracket. Don't need that BS on there.
The step makes gitting into the bed quite a bit easier and feels relatively solid. I use my truck as a farm vehicle and climb in and out of the bed almost daily. This was the last thing I had anticipated needing but I'm glad I put it on as just last week I slipped on the bumper (muddy cow **** on my boots) and almost knocked out some teeth. So far the manure hasn't made me slip on this step, pretty high praise in my book. Now I can get back to solving my oil leaks and upgrading the turbo, hopefully next week. Please Sous don't find any more deals as I'm running low on cash.
Lewis
The 17mm socket called for in the tool list was loose on the supplied hardware, but a 16mm fit dead on. The 21mm was right for the Ford flange nuts, but those suckers were tight as could be in the well of the bracket.
Strange how two trucks from the same year might have different fasteners for a spot you would think is standard across the board.
I agree that the step is going to be very useful.
used pins from tractor supply so I could remove it easier .
I love it . I'm short and truck is tall . If tailgate is down I couldn't get in bed without it.
Bit of a pain in the *** to install, but it appears I was unlucky on that front.
