Anyone know about Remote Starters?
Old Jan 19, 2016 | 08:06 AM
pgguru's Avatar
pgguru
So My Remote Start (code alarm) stopped working recently... the problem is PATS related (will not start and flashed "theft" when turning over..
I've Tried reprograming the Pats like programing a 3rd key but it did not help
remote start works if leave a key in the ignition.
The remote start could be from when the truck was new 2003
Thanks
Old Jan 19, 2016 | 09:17 AM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Look under your dash for the remote start key for the Pats.
( some aftermarket remote start systems use an actual ignition key )
If you reprogrammed your keys you will need to find the remote start key and reprogram it at the same time as your other keys.
Old Jan 19, 2016 | 09:42 AM
03X's Avatar
03X
Thanks
If your remote starter works with the key sitting in the ignition, then the bypass module is not working for some reason (vehicle not getting a fake key signal, or not getting the correct key signal)
Could be one of several problems. Take it to a shop that installs Code Alarm. Should be a quick fix for any decent installer.
Just my $0.02. Good luck! I had lots of remote starter problems (not related to key bypass) and its such a pain!
Old Jan 19, 2016 | 10:41 AM
pgguru's Avatar
pgguru
yes It has a 1L3Z-19G365-AB module in it that does not seem to be working.
I've tried to reprogram it as a 3rd key but its still not working.... Has anyone seen these just die? Maybe I need to replace it?
Thanks
Old Jan 19, 2016 | 01:08 PM
jpr38057's Avatar
jpr38057
Thanks
Part is no longer available from Ford but there are a lot of dealers that show still have some in stock. If you let me know where you are I can give you some dealers that show to have it.
Old Jan 19, 2016 | 04:20 PM
pgguru's Avatar
pgguru
im in Hamilton Ontario Canada
Old Jan 20, 2016 | 01:42 PM
jpr38057's Avatar
jpr38057
Sorry, I can't access Canadian dealers. For all I know the part may still be available north of the border. Two different parts distribution systems.
swillett
1997 - 2003 F150
Dec 12, 2012 07:08 PM
Still Smoking
2004 - 2008 F150
May 9, 2010 11:17 PM
BillyBob69
1997 - 2003 F150
Jul 20, 2005 02:33 PM
gmarkie
1997 - 2003 F150
Mar 11, 2003 10:51 PM
