Vin Decode Help
Old Dec 18, 2018 | 05:00 PM
  #31
James_Western_Canada's Avatar
Well, as far as the front cab mounts go, first off, we need to confirm or deny the chassis was originally Twin I Beam......but, if it indeed was TIB, then it may have been a case of then being very rusted where the cab mount rubbers sit. If you dig around on here, you will find pics of some mounts so badly rusted the rubbers would almost fall through the hole. If the builder had access to a donor chassis, it was probably easier to knock the rivets out and bolt on the donor parts than to cut out the bad parts,and weld in new metal, all the while keeping the center hole the correct size, and in the correct location.....
James
Originally Posted by SixtyFour
Wellll I guess there's nothing '64 about this truck then. I'll check for a frame VIN this weekend and get a pic of the rad arm mounts.
Going back a sec - why is my cab mount bolted on then if the frame would be '65? Wouldn't that match?
Last edited by James_Western_Canada; Dec 18, 2018 at 06:45 PM. Reason: spelling correction
Old Dec 18, 2018 | 05:42 PM
  #32
SixtyFour's Avatar
SixtyFour
Ok that makes sense. I'll look closer at the body mount. But I can confirm it was a Rad arm truck. In these pics you can see the mounts. See the circle/hole above the pumpkin? and in the second pic the bracket thats at the far right of the picture.
Old Dec 18, 2018 | 09:32 PM
  #33
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by TA455HO
The floorboards, clutch and brake pedals, steering column, and floor mat are indicating 1965/1966 and the floating gas pedal is indicating 1965 "From Serial 696,001" and 1966.
1966 F100 4WD has coil spring front suspension and radius arms.
1961/65 F100 4WD has leaf spring front suspension.
Does the VIN on the Warranty Plate match the VIN on the registration/title?
Warranty Plate decodes to a 1964 F100 2WD, and since it's attached with screws instead of rivets, some "hanky-panky" may have occurred.
Old Dec 19, 2018 | 01:04 PM
  #34
SixtyFour's Avatar
SixtyFour
Title and Door plate VIN match. Haven't checked the frame VIN but we know that wont match since it has the radius arm mounts. Hanky-Panky for sure.
For parts buying purposes am I good if i go with: '65 2WD parts? Mainly looking into freshening up the cab...floor mat, visors, firewall pad, etc.
Old Dec 19, 2018 | 09:27 PM
  #35
NumberDummy
Does this help - you can see the inner fender, it's very boxy and squared off looking. Below pic you can kinda see a cab mount on the passenger side.
If the valve covers and oil fill tube are an indication, this engine was swapped from a car.
The THUNDERBIRD valve covers (they were gold originally) were used on 1961/64 Galaxie & Thunderbird w/a 390.The engine oil fill tube was used on all 1958/64 FE engines.
FE engines were not installed in F100/350's until 1965, then used different valve covers with holes in them for oil fill cap (left front) and smog valve (right rear).
No FE engines have an oil fill tube after 1964. The bolt pattern on the 1958/64 FE blocks used for the rubber motor mount insulators is different than 1965/76.
Old Dec 20, 2018 | 10:59 AM
  #36
SixtyFour's Avatar
SixtyFour
Thanks this confirms what i was told about the engine - FE390 from a '64 T-Bird. But again in my last post for Cab parts I plan to buy to freshen the interior...am I good if i go with: '65 2WD parts? Again mainly looking for things like a new floor mat, visors, firewall pad, door panels, etc.
Old Dec 20, 2018 | 11:05 AM
  #37
NumberDummy
The cab pictured in post #15 is 1965/66 F100/250 2WD & 1966 F100 4WD
Old Dec 20, 2018 | 11:31 AM
  #38
SixtyFour's Avatar
SixtyFour
Ok it looks like mine except my dash/gauges are different - big circle.
Old Dec 25, 2018 | 10:25 AM
  #39
1964FORDTUF's Avatar
1964FORDTUF
This is a nice looking rig as Chad mentions, I would add that if my eyes are seeing it correctly, it has open knuckle front axle in it. A lot has been swapped around on the truck, probably best to start with the frame VIN number if you can find it. Have fun!
Old Dec 25, 2018 | 10:37 PM
  #40
Christmas's Avatar
Christmas
Disc's too.
Old Dec 26, 2018 | 05:25 AM
  #41
1964FORDTUF
Originally Posted by Christmas
Disc's too.
Looks possibly to be a Dana 60 out of late 78-79 era, also add on cross over steering set up. Measure width of front springs, if 3" wide my guess is close. Maybe PO had a later donor truck and that's ho he got the cab mounts, axle, etc.
Where is the transfer case located on this truck? Is it divorced or bolted right up to the 4 speed trans?
Chisum5013
Feb 10, 2016 06:03 PM
fordtech08
Feb 21, 2014 05:47 PM
63ferd
Feb 19, 2014 07:28 PM
unibudd
Mar 3, 2009 03:30 PM
bluecrowbar
Mar 2, 2006 06:43 PM
