VIN help
Old Feb 10, 2016 | 05:31 PM
Chisum5013's Avatar
Chisum5013
VIN help
Could someone please help me decode this VIN on my 1961 F100, (F10JR80485). I have also attached a few photos of the VIN, not the best pictures but hopefully they will do. Thanks in advance for your help.
Old Feb 10, 2016 | 05:36 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I can't see your pictures clearly enough to make out anything specific even on my largest monitor - and the VIN you typed in isn't correct for a 1961 as the last 6 if it starts with an 8 would be 1966.
See if you can get a closer picture of the Warranty plate. It's got all the other good info and a picture usually prevents any typos.
Old Feb 10, 2016 | 05:42 PM
whomrig's Avatar
whomrig
looks like a typ-o
I think it is F10JR180485
here is what I got
VIN Format: 1961-1980 Ford truck
Decoding: F10JR180485
Digit
Usage
VIN
Decoded
1-3 Series F10 F100 2WD pickup
4 Engine J L6 223-1v 114hp 3600rpm
5 Plant R San Jose CA
6-8 Mod Yr/Mfg Date 180 1961 (Mfg Jun 1961)
6-11 Sequential Serial # 180485 180485
Serial numbers are sequential per plant
Old Feb 10, 2016 | 06:03 PM
Chisum5013's Avatar
Chisum5013
You are right, I must of fat finger it. the correct VIN is F10JR18048, it also has 114 under W.B, F100 under model, A under Trans, 11 under axle, 05000 under MAX GVW LBS, 114 under CERT, 3600 under RPM, 9985 der DSO. I attach another picture, maybe it will help. Thanks for your help.
gangstakr
Dec 13, 2014 12:47 PM
63ferd
Feb 19, 2014 07:28 PM
alabbasi
Sep 19, 2006 10:49 PM
dixiefried
Apr 25, 2006 12:49 PM
old henry
Sep 9, 2004 05:12 PM
