Gearshift pointer
Old Dec 15, 2018 | 10:14 PM
1981 F100's Avatar
1981 F100
Question Gearshift pointer
I have the shift linkage working on my 1981 F100, but the pointer for the PRND21 on the instrument cluster is not moving. Anyone have a diagram showing what I need to repair/replace, and is this an item that LMC would carry?
Old Dec 15, 2018 | 10:25 PM
kramttocs's Avatar
kramttocs
If you take off the black plastic piece that wraps around the steering column you should see a white sheathed cable that comes from the dash cluster, wraps clockwise around the steering column and loops over a pin. The cable and a spring is what moves the indicator.
Old Dec 15, 2018 | 10:29 PM
1981 F100's Avatar
1981 F100
Ok thanks I will do that.
Old Dec 15, 2018 | 10:34 PM
kramttocs's Avatar
kramttocs
I looked on Gary's site but didn't find a diagram besides a partial image of the cable on the steering column page. If you need something tonight I can run out to the shop and take a photo of a pulled steering column that has the gear shift indicator hanging on it.
If the cable is broken I think your best best is replacing the indicator and cable as 1 piece from a junkyard. You might be able to replace the cable but I've never looked to see how it attaches inside the indicator.
Old Dec 16, 2018 | 07:49 AM
Franklin2's Avatar
Franklin2
It's probably broken, the "cable" is very brittle plastic. Basically, it's a small plastic tube with a string inside it. It's very easy to break it if you try to pull the cluster without disconnecting it first.
Old Dec 16, 2018 | 11:26 AM
1981 F100's Avatar
1981 F100
Now the big question, Is this an 80-86 part only, or will something from an 87-91 work?
Old Dec 16, 2018 | 01:15 PM
kramttocs's Avatar
kramttocs
Since the cluster changed in 87 I would guess this changed also. Never looked at an 87 so again, just a guess. Have a jy around you? Should be able to find one pretty easily. The white sheath has a good chance of being cracked but functionally it will still work.
Old Dec 16, 2018 | 01:23 PM
kramttocs's Avatar
kramttocs
Here I said I'd never looked at how it attaches inside the indicator but I guess I should have said I never paid attention 😊
Here is the one out in my shop. I didn't pull the cover off the column but there's not much going on under there besides a little clip and then a black plastic screwed on pin the cable hooks to.
Old Dec 16, 2018 | 08:37 PM
1981 F100's Avatar
1981 F100
Yes, there's a junkyard about 3 miles west of my place
Old Dec 17, 2018 | 05:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1987/91 will not work.
1980/86 is the same if the trans is a C4/C5/C6.
If it's an AOD, 1981/82 is one type, 1983/86 is different.
travistalbot
Nov 1, 2012 08:29 PM
chevyklr
Sep 13, 2006 09:42 AM
MikeD916
1983 - 2012 Ranger & B-Series
Jul 1, 2004 08:53 AM
tbird46
Aug 11, 2003 08:39 AM
Bren4x4
1978 - 1996 Big Bronco
Mar 9, 2003 11:27 AM
