2002 7.3 Powerstroke no start
Old Dec 15, 2018 | 10:22 AM
Jhulsey99's Avatar
Jhulsey99
I’ve got a 2002 f350 7.3 PSD, and I’ve come to a point where I’m pretty well stumped. It started when I had to replace the steering gear box on the truck, then I noticed a significant oil leak that was diagnosed as the HPOP. So I removed the pump, did a complete reseal and replaced the IPR valve, and now the truck will not start. I’ve put a code reader on the truck and it reads an IPR duty cycle of 65% and an ICP of 270 psi. Knowing that the truck needs at least 500 psi to fire, I’ve pulled the HPOP off three times and verified that every seal is in place, the check ball on the “non-serviceable” port is in place, and the hp oil lines are installed correctly. The new IPR valve is genuine motorcraft brand. Another symptom that I noticed was that the fuel system was not pressurizing, so I proceeded to check every fuse for continuity, and there were no blown fuses. If I remove fuse number 22 (ECM), then the fuel pump will come on and pressurize the system. I’ve check the ICP sensor and the IPR sensor and both seem to be in working order, so I’m stumped. Does anyone have any ideas?
Old Dec 15, 2018 | 10:30 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Sounds like you have done a good deal of cranking trying to get ICP pressure, what is your current battery voltage ?
what RPM is it cranking over at ? Burning up a starter and or draining the batteries is not uncommon.
Old Dec 15, 2018 | 10:39 AM
Jhulsey99's Avatar
Jhulsey99
I’ve had the truck connected to the charger to keep the batteries strong. The engine is turning over at 180 rpms, battery voltage is between 11-12.4 volts. Starter is brand new.
Old Dec 15, 2018 | 12:49 PM
Walleye Hunter's Avatar
Walleye Hunter
In my signature is a link to a no-start troubleshooting guide. The 7.3 is down the page a bit. It should help you out.
Old Dec 15, 2018 | 11:37 PM
timmyboy76's Avatar
timmyboy76
How does removing a fuse, allow equipment to be energized? Have you tried the original ipr?
Old Dec 16, 2018 | 07:34 AM
Jhulsey99's Avatar
Jhulsey99
I’m not sure, that’s why I’m puzzled. Yes, I tried the factory IPR and the readings were the same
Old Dec 16, 2018 | 07:49 AM
Wes444's Avatar
Wes444
I didnt see it stated so I'll ask, have you tried starting it with the ICP sensor unplugged? Checked the inertia switch at the passenger kick panel by the door?
Old Dec 16, 2018 | 09:14 AM
Jhulsey99's Avatar
Jhulsey99
i did try starting it with the ICP sensor unplugged and no dice. I have not checked the inertia switch, is it by the fuel reset? What exactly would I be checking?
Old Dec 16, 2018 | 10:04 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Old Dec 16, 2018 | 11:17 AM
Walleye Hunter
Thanks, I also needed that!
Old Dec 16, 2018 | 02:52 PM
Jhulsey99's Avatar
Jhulsey99
Alright so I checked the inertia switch and it is set correctly, but is there a way I could test if the switch itself is bad? Would the inertia switch make sense as to why when fuse number 22 is removed the fuel pump suddenly has power? Or is it more likely to be a different sensor or connector?
Jmmason2626
May 26, 2018 01:37 AM
Tonak97
Nov 22, 2017 11:43 PM
jackhardy
May 29, 2013 11:54 AM
srqdiesel chef
Jan 30, 2009 04:24 PM
browe
Jun 19, 2008 09:26 AM
