heater hose fitting
Old Dec 10, 2018 | 03:06 PM
jniolon's Avatar
jniolon
old and in the way
heater hose fitting
'm working on heater hose connections from the firewall bulkhead fitting to the water pump and intake manifold and have hit the wall.
The inlet for the intake manifold is on the very front of the manifold and within 3/4" of the bypass hose. I'd live to put a 90 degree fitting in
there to make hose install a lot easier but because of the proximity of the bypass hose nothing will turn into the manifold.. I've tried all kinda
combinations of nipples and 90's and can't find a solution...
any suggestions ???
Old Dec 10, 2018 | 03:27 PM
52 Merc's Avatar
52 Merc
Can you make one of these work? It's about as compact a 90 fitting as you'll find. Perhaps remove the bypass nipple, install the heater fitting, then reinstall the bypass nipple. Did you thread the intake for the bypass nipple? Those, I've found, were a press fit and prone to failure in the aftermarket manifolds. Short of that, you may be looking at a heater hose with a molded in 90 bend.
Old Dec 10, 2018 | 03:35 PM
jniolon's Avatar
jniolon
old and in the way
Wayne, thanks for that... I'll try to find one in 1/2" npt.. You DO know how impossible that bypass hose is to install/remove without removing the water pump, right ?? it is a threaded fitting at the manifold and a short nipple at the water pump. I really REALLY hope that isn't the solution... I'll look for the brass one you showed..
john
Old Dec 10, 2018 | 03:48 PM
gerrymoe's Avatar
gerrymoe
Take a look at street elbows, they will give you a little more clearance from the head
https://www.mcmaster.com/street-elbows
Old Dec 10, 2018 | 03:51 PM
jniolon's Avatar
jniolon
old and in the way
already tried a street elbow... even tried a 1/2-3/8 adapter in the manifold and a 3/8 street elbow.. still hitting the bypass tube... I love when things go together with no problems !!!!!
Old Dec 10, 2018 | 04:10 PM
gerrymoe's Avatar
gerrymoe
John
Check the spec drawings at the bottom of the page this one is very close. Check the centerline demension
https://www.mcmaster.com/4429k153
Old Dec 10, 2018 | 04:13 PM
hulleywoodworking's Avatar
hulleywoodworking
Looking at your picture, I wonder if removing the bypass fitting, which appears to be straight, would give you the clearance to install the 90?
Old Dec 10, 2018 | 04:27 PM
56panelford's Avatar
56panelford
Old Dec 10, 2018 | 04:33 PM
gerrymoe's Avatar
gerrymoe
Another idea. How about two of these, one installed at a time and will give clearance from head
https://www.mcmaster.com/50785k84
Old Dec 10, 2018 | 10:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D1AZ-18599-A .. Elbow - 90 degree / 1/2" -14 engine connection; 5/8" heater hose connection / Obsolete
1971/73 429 Passenger Cars // 1971/78 460 Passenger Cars /// 1973/79 F100/350 460 // 1983/91 F250/350 460.
1965/72 car parts catalog sez: attach heater hose to intake manifold.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
Shown as TYPE #13 in pic:
Old Sep 27, 2024 | 10:07 AM
55F250's Avatar
55F250
AirForceVet
Question Same problem
any suggestions ???
I have the same problem, what did you end up doing?
Old Sep 27, 2024 | 10:56 AM
jniolon's Avatar
jniolon
old and in the way
I used two 45 street ells similar to #13 in Numberummy's pic above and then bushed up to the hose size I needed (5/8"???) Now, this is on a 460 with an Edlebrock Performer manifold YMMV
j
Old Sep 27, 2024 | 03:10 PM
gerrymoe's Avatar
gerrymoe
Deleted I already provided input, should have read before I posted
OneFine69
Mar 4, 2008 01:25 PM
FloridaFord250
May 9, 2006 12:55 PM
02superstroker
1966 - 1977 Early Broncos
Feb 15, 2004 11:36 PM
luvfordtrucks
Feb 8, 2004 09:01 PM
Rascal2k
1978 - 1996 Big Bronco
Nov 28, 2003 11:47 AM
