Power Steering Too Strong
Old Sep 23, 2024 | 10:01 AM
pltnsgt06's Avatar
pltnsgt06
Good Morning,
Can your power steering be to strong? It seems when I drive my truck that I need more stiffness in the wheel at faster speeds. Sitting still you can rotate the wheel with one finger no issue. Seems a bit strong to me but I have not been able to find a reducer valve or much mentioning of it on the internet.
My setup is:
1954 F100
1977 Dodge Aspen front clip with ps steering box
1984 302 ps pump
I had the lines married together
Thanks,
Will
Last edited by pltnsgt06; Sep 23, 2024 at 10:33 AM. Reason: Seems I cannot spell.....
Old Sep 23, 2024 | 11:50 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Heidt's make an adjustment valve that goes inline to reduce pressure and increase turning effort. I chose to go with a Borgensen box but I saw you just replaced yours with a factory style rebuilt. Here is a link.
https://www.google.com/url?sa=t&sour...rvADr4rHsxE2Ke
Old Sep 23, 2024 | 12:41 PM
pltnsgt06's Avatar
pltnsgt06
Delete, wrong post.
Old Sep 23, 2024 | 03:53 PM
pltnsgt06's Avatar
pltnsgt06
Got it, I think that will work! I read the destructions and it calls for a 3/8 push on barb return line. For the pressure sides it maybe a little more difficult, it calls for a 1/4 fitting. So, I am going to take the the adjustment valve when I get it in the mail, pressure line I had made (Dodge steering box to Ford power steering box) down to the local hydraulic line shop and see if they can marry the valve in the line and get me the push on barb adapter as well. I am thinking this maybe a little more then the local parts store can do.
Thanks again for the link!
​​​​​​​Will
Old Sep 23, 2024 | 05:40 PM
5851a's Avatar
5851a
You can adjust the CII pressure with different springs under the outlet port. Ford used same pump on an Escort as a F-350. Too late now but hope your solution works well.
Old Sep 23, 2024 | 07:25 PM
49willard's Avatar
49willard
I remember driving a friends 56 ford truck many years ago with the same front end. My experience was exactly the same as you have experienced.
Old Sep 23, 2024 | 08:21 PM
jniolon's Avatar
jniolon
old and in the way
seems I remember the reducing valve goes in the pump body then attach the line
that's with a saginaw box
john
Old Sep 23, 2024 | 09:24 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
As 5851a said, the pumps are typically all the same. I'm not as confident on the Ford and Mopar pumps, but on the Saginaw pumps the regulator is on the pressure outlet. The same pump is used on the little small cars and the big road boats, trucks, etc. If you remove the regulator from the box there is a stack of washers (shims) between the regulator on the body of the pump.
I can't remember if its more shims for higher pressure or less shims for higher pressure.
Bobby
Old Sep 27, 2024 | 08:27 PM
pltnsgt06's Avatar
pltnsgt06
Let’s start by it is in and it works great, but damn sure was not a cake walk. I dropped the valve off at a hydraulic shop this morning and they did all the fittings and plumbing for just over $70.00. The issue was there is no room for the lines to attach without crimping. The lines for the return from the pump to the valve to the steering box is just too tight for a strait shot. I had some line that was tight in the spool and I was able to use the curbs to connect everything, in the end it worked but a project that should have taken an hour took almost three. Below are a before and after. Will fine tune everything on a road trip tomorrow.
Thanks again for the tip!
Will
Before
After
Old Sep 27, 2024 | 09:17 PM
truckeemtnfords
Will, glad it is working for you. Now you know why I went the Borgensen box as opposed to a factory box and the reducer valve.
Old Sep 27, 2024 | 09:32 PM
pltnsgt06's Avatar
pltnsgt06
Yes I do, lol. The next poor sap will be able to see the pictures from mine and maybe go a different route. On a positive side I do enjoy working with my hands and my dad’s tool box. While I was in the service it was difficult to do much knuckle busting. Now I have a shop and most all the tools I need to get the truck back up and running.
Thanks again,
Will
h.ubk
Sep 24, 2021 02:38 AM
icovy
Dec 12, 2006 06:03 AM
mopower
Aug 10, 2004 02:25 AM
Adriand
Mar 15, 2004 06:14 AM
Trail_Rider
Mar 5, 2002 01:29 PM
