No 4 Wheel Drive
Old Dec 9, 2018 | 07:54 AM
Lockholder's Avatar
Lockholder
No 4 Wheel Drive
When i turn the switch to 4h or whatever nothing happens no lights or anything. When i turn the key to on the light for 4x4 comes on but nothing with the switch happens, i swapped the switch out with a known good one and still nothing happens.
Old Dec 9, 2018 | 08:02 AM
AllaboutMPG's Avatar
AllaboutMPG
2 trucks in your signature. which one? Think you need to check fuses but those trucks will have different fuse panels
Old Dec 9, 2018 | 08:12 AM
Lockholder's Avatar
Lockholder
Sorry my fault 2003 F350 7.3L
Old Dec 9, 2018 | 08:19 AM
AllaboutMPG
Looking at the owners manual for 2003 f350 fuse 111 is 30 amp 4wd shift on the fly. Have you checked this fuse yet?
http://www.fordservicecontent.com/Fo.../03f23og5e.pdf
Old Dec 9, 2018 | 08:24 AM
Lockholder's Avatar
Lockholder
i've checked fuses relays and replaced them even if they were "good". i'll check that fuse again though
Old Dec 9, 2018 | 08:56 AM
FordTruckNoob's Avatar
FordTruckNoob
I'm using my phone so I can't see sigs. I'm assuming you have ESOF since you said "turn the switch". Can you hear the actuator motor on the transfer case moving when you turn the switch? Check the connector to the motor. Is it fully inserted? Any chafed wires? If the wiring is okay, try taking the motor off the transfer case so the motor is not loaded when turning. If the motor turns okay off the TF, try turning the shaft on the TF with channel locks. If it takes a lot of force, you have a jammed TF. When was the last time your 4x4 worked?
Old Dec 9, 2018 | 09:13 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Check the plug/connector on the transfer case to see if has come unplugged.
Check to listen for the motor on the transfer case to try and engage 4x4.
Turn the switch to 4x4 and roll the truck forward 10 feet or so slowly and see if it engages.
Do you have manual or automatic hubs?
Does your vacuum pump work and if so, does it shut off after a short amount of time and building vacuum?
Taken from page 128 of the manual.
To prevent damage, the
electronic shift 4WD system is
designed to engage 4x4 HIGH
(4WD high) when the vehicle
is moving. If the 4x4 indicator
light does not illuminate when
shifting a vehicle that is
stationary, start the vehicle
moving. Once the vehicle is moving, 4x4 HIGH (4WD high) will
engage and the 4x4 indicator will illuminate.
Do not shift into 4x4 HIGH with the rear wheels slipping.
Old Dec 9, 2018 | 06:54 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Reminds me I need to check to see if mine is working before I go out in the snowy mountains. Wasn't there something about being in NEUTRAL when you turn switch..... or was that for low range 4x4?
Old Dec 9, 2018 | 07:31 PM
Lockholder's Avatar
Lockholder
Yeah 2wd 4hi 4lo on a dial switch no noise or anything. i checked the switches and all connections before and no issues. i haven't taken the motor out or checked the TF before. 4x4 been out since i had the truck. manual hubs
Old Dec 9, 2018 | 09:14 PM
FordTruckNoob
Being in neutral as well brakes on and traveling at close to a standstill is for 4-Lo.
The shift motor comes off pretty easily. Just take note of what position the shaft and the motor are in when you take them off. They are probably in 2-Hi but it doesn't hurt to be cautious.
You will notice the shift motor has slotted holes that the bolts holding it onto the TFC pass through. Those are so you can adjust the shift position. The shaft on the TF doesn't turn very much to shift into one of the three modes. Bear that in mind when you put the motor back on so you don't accidentally shift the TFC into a position the system is not expecting, TFC in 4-Hi with shift motor in 2-Hi for example.
I'll dig up the relevant picture from the shop manual when I am in front of the PC again.
Old Dec 9, 2018 | 10:27 PM
pirate4x4_camo's Avatar
pirate4x4_camo
looking at the shaft, full clockwise is 2wd , rotating counterclockwise the first detent is 4hi and the next is 4lo, these detents are where the tcase needs to be in each gear, Even if you use a 15mm open end wrench to shift the tcase you have to align the gearmotor back with the slot, The range indicator will adjust with the motor, ford used no tamper torx bolts for a reason, the range indicator is calibrated using an ohm meter so unless you have a factory service manual I suggest not adjusting the black plastic range indicator that the wires plug into.
Once you have the shift motor off you can test it by supplying 12v + and - to each terminal,
you might want to use a sharpie to index the slot to the case so you can get it back into position. A 3/8 ratchet extension fits in the slot and you can align it back up.
There are several inputs that go to making the ESOF function and a scan tool to pull ford codes is useful, it could be anything from your ignition switch, MSS, ABS, VSS, TRS, Brake pedal switch or the GEM itself.
Honestly I think the ESOF has more Vodoo then an automatic transmission
Old Dec 9, 2018 | 10:36 PM
coax9952's Avatar
coax9952
My bet is His Vac pump is Dead.....
Old Dec 9, 2018 | 10:52 PM
pirate4x4_camo
he has manual hubs, no vacuum needed for the transfer case operation only the hubs and climate control panel.
The vacuum pump and PVH part of the system is a output from the GEM not an input so even if it were bad it wouldn’t stop the tcase from shifting.
Old Dec 16, 2018 | 07:31 AM
FordTruckNoob
Sorry this took so long.
Old Dec 17, 2018 | 06:26 AM
Tugly's Avatar
Tugly
Those instructions crack me up. If I could get the damn thing into 4X4 HIGH, I wouldn't be reading the manual on the transfer case motor in the first place. Do they specify how this is done manually? I ask, because mine failed - and I'm getting ready to replace it this week.
