No 4 Wheel Drive
Old Dec 17, 2018 | 09:37 PM
00t444e's Avatar
00t444e
Originally Posted by Tugly
Those instructions crack me up. If I could get the damn thing into 4X4 HIGH, I wouldn't be reading the manual on the transfer case motor in the first place. Do they specify how this is done manually? I ask, because mine failed - and I'm getting ready to replace it this week.
It doesn't matter what position it is in when you remove it, you can manually switch it to whatever position the motor is in before you install it.
Old Dec 19, 2018 | 05:04 AM
Tugly's Avatar
Tugly
I tested my new transfer case motor before I installed it - the light popped on. So... 15 minutes later, Stinky's in 4X4 in the driveway. Don't buy a Dorman part - get reman or OEM. I bought mine at the shamrock auto parts store. I'm not putting anything expensive or shiny under there - they started salting our roads in the winter a few years back.
Old Feb 15, 2019 | 03:54 PM
Lockholder's Avatar
Lockholder
sorry to bring a dead forum back but i kind of need my 4x4 to work. so i need a new transfer case motor?
Old Feb 16, 2019 | 06:35 AM
Tugly's Avatar
Tugly
I did electrical tests before I called mine dead. There is supposed to be a winding for forward and one for reverse (in/out of 4X4), and my forward winding read open. The transfer case motor will make the light on the dash not work and it will throw a code. The ESOF hub locks give no indication when they fail... other than slip and slide.
Old Feb 16, 2019 | 01:11 PM
Lockholder's Avatar
Lockholder
So i get no code what so ever, only code i get is for my glow plug relay which i have on a switch. but the only thing i know is if i lock my hubs and turn the dial to 4 hi nothing happens. no light comes on the dash. but what youre saying is it'll make a noise when it's trying to engage?
Old Feb 25, 2019 | 08:26 PM
Lockholder's Avatar
Lockholder
I bought a new Tcase motor hooked it up and flipped the switch to 4hi and still no light
Old Feb 26, 2019 | 04:58 AM
FordTruckNoob's Avatar
FordTruckNoob
Take the motor off the tcase and see if it turns when you flip the switch.
c delisio
Jan 26, 2016 06:11 PM
tfarris
Sep 11, 2012 04:25 PM
Montana2mass
Sep 25, 2008 02:20 PM
RIGHTcoastRIOT
Jun 21, 2008 07:48 PM
rickppph
Electrical Systems/Wiring
Sep 14, 2006 02:54 PM
